Aller au contenu principal
Acer Aspire 4520-5464 Hard Drive Replacement
Ce dont vous avez besoin
  1. Acer Aspire 4520-5464 Hard Drive Replacement, Battery: étape 1, image 1 de 1
    • Shut down the computer and disconnect all external devices and cables.
    • Flip the computer over.
  2. Acer Aspire 4520-5464 Hard Drive Replacement: étape 2, image 1 de 2 Acer Aspire 4520-5464 Hard Drive Replacement: étape 2, image 2 de 2
    • Ensure that the battery compartment lock tab is in the unlocked position.
    • Slide the sliding black tab away from the battery compartment.
    • The inside edge of the battery should be released, causing it to slightly pop out of the compartment.
  3. Acer Aspire 4520-5464 Hard Drive Replacement: étape 3, image 1 de 1
    • Grasp the inside edge of the battery and lift to fully detach the battery from the computer.
  4. Acer Aspire 4520-5464 Hard Drive Replacement, Hard Drive: étape 4, image 1 de 3 Acer Aspire 4520-5464 Hard Drive Replacement, Hard Drive: étape 4, image 2 de 3 Acer Aspire 4520-5464 Hard Drive Replacement, Hard Drive: étape 4, image 3 de 3
    • Remove the seven 2mm Phillips #1 screws from the largest panel on the back of the laptop
    • Lift up the panel from the indent located on the right side.
  5. Acer Aspire 4520-5464 Hard Drive Replacement: étape 5, image 1 de 3 Acer Aspire 4520-5464 Hard Drive Replacement: étape 5, image 2 de 3 Acer Aspire 4520-5464 Hard Drive Replacement: étape 5, image 3 de 3
    • Remove the two 0.5mm Phillips #1 black screws left of the Hard Drive.
    • Remove the two 0.5mm Phillips #1 silver on top of the Hard Drive.
    • Lift up and remove the hard drive bracket by the plastic tab on top of the hard drive.
  6. Acer Aspire 4520-5464 Hard Drive Replacement: étape 6, image 1 de 1
    • Remove the hard drive from the device.
Hunter Gilcrease
Membre depuis le 09/21/17
367 Réputation
3 tutoriels rédigés
Équipe
Washington State, Team S5-G117, Phelps-Hillen Fall 2017 Membre de l'équipe Washington State, Team S5-G117, Phelps-Hillen Fall 2017
WSU-PHELPS-HILLEN-F17S5G117
3 membres
7 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 5
30 derniers jours : 15
Total : 828
