Aller au contenu principal
Acer Aspire 4520-5464 RAM Replacement
Ce dont vous avez besoin
  1. Acer Aspire 4520-5464 RAM Replacement, Battery: étape 1, image 1 de 1
    • Shut down the computer and disconnect all external devices and cables.
    • Flip the computer over.
  2. Acer Aspire 4520-5464 RAM Replacement: étape 2, image 1 de 2 Acer Aspire 4520-5464 RAM Replacement: étape 2, image 2 de 2
    • Ensure that the battery compartment lock tab is in the unlocked position.
    • Slide the sliding black tab away from the battery compartment.
    • The inside edge of the battery should be released, causing it to slightly pop out of the compartment.
  3. Acer Aspire 4520-5464 RAM Replacement: étape 3, image 1 de 1
    • Grasp the inside edge of the battery and lift to fully detach the battery from the computer.
  4. Acer Aspire 4520-5464 RAM Replacement, RAM: étape 4, image 1 de 2 Acer Aspire 4520-5464 RAM Replacement, RAM: étape 4, image 2 de 2
    • Remove the seven 2mm Phillips #1 screws from the largest panel on back of the laptop.
    • Lift up the panel from the indent located on the right side.
  5. Acer Aspire 4520-5464 RAM Replacement: étape 5, image 1 de 3 Acer Aspire 4520-5464 RAM Replacement: étape 5, image 2 de 3 Acer Aspire 4520-5464 RAM Replacement: étape 5, image 3 de 3
    • Push the white tabs located on either side of the top stick of RAM outward.
    • Remove the RAM from the slot on the motherboard.
    • Repeat for the bottom stick of RAM.
Ethan Woltersdorf
Membre depuis le 09/21/17
270 Réputation
2 tutoriels rédigés
Équipe
Washington State, Team S5-G117, Phelps-Hillen Fall 2017 Membre de l'équipe Washington State, Team S5-G117, Phelps-Hillen Fall 2017
WSU-PHELPS-HILLEN-F17S5G117
3 membres
7 tutoriels rédigés
Un commentaire
interesting good job
Maren Eras - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 10
Total : 1,228
