Aller au contenu principal
Acer Aspire 5100 LCD Monitor Replacement
Ce dont vous avez besoin
  1. Acer Aspire 5100 LCD Monitor Replacement, Keyboard: étape 1, image 1 de 2 Acer Aspire 5100 LCD Monitor Replacement, Keyboard: étape 1, image 2 de 2
    • Open and push the screen back all the way until it is horizontal with the rest of the laptop.
    • Use an opening tool to remove the panel above the keyboard that has the power button on it.
    • After you have released the tabs, lift up the panel.
  2. Acer Aspire 5100 LCD Monitor Replacement: étape 2, image 1 de 3 Acer Aspire 5100 LCD Monitor Replacement: étape 2, image 2 de 3 Acer Aspire 5100 LCD Monitor Replacement: étape 2, image 3 de 3
    • Under the panel, remove the two screws that connect the keyboard to the laptop.
    • One screw is located above the F5 button, and the other one is located above the F10 button.
    • Potential for device damage: Lift up the keyboard CAREFULLY because there is a ribbon that connects the keyboard to the motherboard.
  3. Acer Aspire 5100 LCD Monitor Replacement: étape 3, image 1 de 1
    • Release the catch on the ribbon socket by sliding the two tabs toward the ribbon.
    • Pull the ribbon under the keyboard to detach it from the motherboard.
    • Remove the keyboard.
  4. Acer Aspire 5100 LCD Monitor Replacement, LCD Monitor: étape 4, image 1 de 1
    • Remove the two screws from each corner beneath the LCD screen.
  5. Acer Aspire 5100 LCD Monitor Replacement: étape 5, image 1 de 2 Acer Aspire 5100 LCD Monitor Replacement: étape 5, image 2 de 2
    • Detach the white rectangle located on the motherboard at the end of the wire connected to the LCD screen.
  6. Acer Aspire 5100 LCD Monitor Replacement: étape 6, image 1 de 2 Acer Aspire 5100 LCD Monitor Replacement: étape 6, image 2 de 2
    • Flip the laptop upside down.
    • Remove the four screws from the back panel of the laptop.
    • Lift the panel up and set it aside.
  7. Acer Aspire 5100 LCD Monitor Replacement: étape 7, image 1 de 1
    • Detach the black and white wire.
    • You do not need to remove the cooling fan.
  8. Acer Aspire 5100 LCD Monitor Replacement: étape 8, image 1 de 1
    • Lift up the monitor to detach it.
8 autres ont terminé cette réparation.
Brad Rollinson
Membre depuis le 09/29/10
1 113 Réputation
7 tutoriels rédigés
Équipe
Cal Poly, Team 14-39, Forte Fall 2010 Membre de l'équipe Cal Poly, Team 14-39, Forte Fall 2010
CPSU-FORTE-F10S14G39
5 membres
10 tutoriels rédigés
Un commentaire
There are 2 screws at the back corners on the bottom cover that are holding the screen down. They need to be removed in order for the screen to be lifted.
Kar Wong - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 2
30 derniers jours : 21
Total : 15,455
