Introduction
Upgrade or replace RAM.
Remove the screws on the large panel. Lift up the panel.
  • Remove the screws on the large panel.
  • Lift up the panel.
Ajouter un commentaire
The RAM slots are located in the corner opposite to the cooling fan. To remove existing RAM cards: there are clips holding the sides of each card. Simultaneously spread both right and left clip and the card will pop upward. Then it can easily be pulled out. Slide in the RAM at a 45 degree angle.
  • The RAM slots are located in the corner opposite to the cooling fan.
  • To remove existing RAM cards: there are clips holding the sides of each card. Simultaneously spread both right and left clip and the card will pop upward. Then it can easily be pulled out.
  • Slide in the RAM at a 45 degree angle.
  • Press down on the RAM until it snaps into place.
  • A good amount of pressure is needed to snap it in place.
  • Install the RAM in the left (lower) slot before installing RAM in the right (upper) slot
7 autre(s) ont terminé cette réparation.
Brad Rollinson
Membre depuis le 29/09/2010
1 089 Réputation
8 tutoriels rédigés
Équipe
Cal Poly, Team 14-39, Forte Fall 2010 Membre de l'équipe Cal Poly, Team 14-39, Forte Fall 2010
CPSU-FORTE-F10S14G39
5 membres
9 tutoriels rédigés
being a novice ram replacement i found this to be exactly what i needed to know thankyou very much.
bruce johnson - Réponse
Voir les statistiques:
Dernières 24 heures : 7
7 derniers jours : 14
30 derniers jours : 55
Total : 14,468
