Use spudger to gently pry off open middle cover. Then flip the middle cover over onto the keyboard.
  • Use spudger to gently pry off open middle cover.
  • Then flip the middle cover over onto the keyboard.
Ajouter un commentaire
Use tweezers to detach the cable from the volume button board on the middle cover.
  • Use tweezers to detach the cable from the volume button board on the middle cover.
Finally remove the middle cover completely from the computer.
  • Finally remove the middle cover completely from the computer.
These latches must be released in order for the keyboard to be removed.
  • These latches must be released in order for the keyboard to be removed.
Using a spudger, pry the keyboard from the PC, gently. Lift the keyboard and flip it over, so that it rests on its keys.
  • Using a spudger, pry the keyboard from the PC, gently.
  • Lift the keyboard and flip it over, so that it rests on its keys.
Using your hands, open the latch holding the wire in place, and remove the keyboard. Using your hands, open the latch holding the wire in place, and remove the keyboard.
  • Using your hands, open the latch holding the wire in place, and remove the keyboard.
Turn the laptop off and remove the power cord. Turn the laptop off and remove the power cord.
  • Turn the laptop off and remove the power cord.
Press in the SD Card or the SD Card Dummy if no SD Card is there. Remove card when it pops out. Press in the SD Card or the SD Card Dummy if no SD Card is there. Remove card when it pops out.
  • Press in the SD Card or the SD Card Dummy if no SD Card is there. Remove card when it pops out.
Flip the laptop over on its face, so that the back is showing.
  • Flip the laptop over on its face, so that the back is showing.
Put grounding  strap on one of your wrists and attach the other end to a large  metal object (recommended method).
  • Put grounding strap on one of your wrists and attach the other end to a large metal object (recommended method).
  • If you don't have a grounding strap an alternative approach is to touch a metal object that is either large or connected to the earth. Then avoid doing things that would accumulate static electricity on your body.
  • Touching the internals of your device while you aren't grounded could destroy your laptop.
Unlock the battery by flipping a switch near the release latch. Unlock the battery by flipping a switch near the release latch.
  • Unlock the battery by flipping a switch near the release latch.
Slide the release latch. This will release the battery from the PC.
  • Slide the release latch. This will release the battery from the PC.
Using your hands, pry the battery free of the computer. Using your hands, pry the battery free of the computer.
  • Using your hands, pry the battery free of the computer.
Unscrew the 2 captive screws and 3 M2.5 x L8 screws holding back cover in place. Unscrew the 2 captive screws and 3 M2.5 x L8 screws holding back cover in place.
  • Unscrew the 2 captive screws and 3 M2.5 x L8 screws holding back cover in place.
Use spudger to pry open the back panel. Then lift panel off of the computer.
  • Use spudger to pry open the back panel.
  • Then lift panel off of the computer.
The remove the one M2 x L4 screw that secures the hard drive in place.
  • The remove the one M2 x L4 screw that secures the hard drive in place.
  • Screw not shown in picture
Using a spudger or your hands slide hard drive out of and away from its connector.
  • Using a spudger or your hands slide hard drive out of and away from its connector.
Lift the hard drive out of the computer.
  • Lift the hard drive out of the computer.
Disconnect the black and white antenna cables from the module.
  • Disconnect the black and white antenna cables from the module.
  • Cables not shown.
Remove one M2 x L4 screw, which is securing the WLAN Module. Remove one M2 x L4 screw, which is securing the WLAN Module.
  • Remove one M2 x L4 screw, which is securing the WLAN Module.
Carefully remove the module from the system, using plastic opening tools.
  • Carefully remove the module from the system, using plastic opening tools.
Retrieve the WLAN antenna  wire from underneath the keyboard. Detach the LCD cable from the main board. Detach the LCD cable from the main board.
  • Retrieve the WLAN antenna wire from underneath the keyboard.
  • Detach the LCD cable from the main board.
Remove 2 M2.5 x L8 screws, using your Philips Head. Remove 2 M2.5 x L8 screws, using your Philips Head.
  • Remove 2 M2.5 x L8 screws, using your Philips Head.
Remove 2 M2.5 x L10 from the front side of the PC.
  • Remove 2 M2.5 x L10 from the front side of the PC.
Lift the screen away from the Main board of the PC.
  • Lift the screen away from the Main board of the PC.
Gian Farrell
Membre depuis le 20/03/2018
627 Réputation
6 tutoriels rédigés
Équipe
UMass Dartmouth, Team S3-G6, Peak Spring 2018 Membre de l'équipe UMass Dartmouth, Team S3-G6, Peak Spring 2018
UMASSD-PEAK-S18S3G6
3 membres
9 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 9
Total : 15
