Aller au contenu principal
Acer Aspire 5749 Fan/HeatSink Replacement
Ce dont vous avez besoin
  1. Acer Aspire 5749 Fan/HeatSink Replacement, Fan/HeatSink: étape 1, image 1 de 3 Acer Aspire 5749 Fan/HeatSink Replacement, Fan/HeatSink: étape 1, image 2 de 3 Acer Aspire 5749 Fan/HeatSink Replacement, Fan/HeatSink: étape 1, image 3 de 3
    • Retrieve all Screw's from the bottom of the laptop and organize them into 2 different sets.
    • When removing the back cover gently press on audio connections on the back right of the laptop.
  2. Acer Aspire 5749 Fan/HeatSink Replacement: étape 2, image 1 de 3 Acer Aspire 5749 Fan/HeatSink Replacement: étape 2, image 2 de 3 Acer Aspire 5749 Fan/HeatSink Replacement: étape 2, image 3 de 3
    • Carefully release and unplug every wire that connects to the fan.
  3. Acer Aspire 5749 Fan/HeatSink Replacement: étape 3, image 1 de 3 Acer Aspire 5749 Fan/HeatSink Replacement: étape 3, image 2 de 3 Acer Aspire 5749 Fan/HeatSink Replacement: étape 3, image 3 de 3
    • Release the screw that connects the fan to the base of the laptop. Carefully remove your fan and heat sink.
    • Apply heat paste to the center before replacing the fan and heat sink. Then reinsert the screw and plugs.
8 autres ont terminé cette réparation.
JeanChristophe
Membre depuis le 11/19/10
523 Réputation
3 tutoriels rédigés
5 commentaires
May need to expand the "apply heat paste to center" section. Need to remove old paste first, etc. etc. A good bird's eye view intro, though
polishtext4 - Réponse
Tanks you…
I'll look forward for adding this info.
JeanChristophe -
Seemed like I was going to rip the motherboard up where the usb ports are by the audio connector, why isn't the %#*@ thing screwed down? Lol If I push down by the audio connector like you mention and pull it up from the other side will ot be fine, felt and looked like I might snap the board.
Clayton Boyle - Réponse
Good job, did have to Emphasis about releasing the audio connectors
Thaine Ferris - Réponse
I didn't know how to explain better…
Some trick of trade?
JeanChristophe -
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 7
30 derniers jours : 42
Total : 7,658
