Introduction
This guide will show you how to remove the keyboard of your device in order to replace it. You may need to do this if it has become non-responsive or faulty, or if keys are missing.
Make sure the device is unplugged and completely powered down. Turn the device over.
  • Make sure the device is unplugged and completely powered down.
  • Turn the device over.
Ajouter un commentaire
The lock switch can slide either towards or away from the battery.  If it is pushed towards the battery, the release switch is locked and the battery can not be released. Slide the switch away from the battery.
  • The lock switch can slide either towards or away from the battery. If it is pushed towards the battery, the release switch is locked and the battery can not be released.
  • Slide the switch away from the battery.
The battery release switch is just to the inside of the battery and slides parallel to it. Push the switch to the side. It is not just an open or close switch, it actually pops the battery up so you will feel some resistance. When inserting a battery back into the device, you do not need to touch this switch. Just press the battery firmly down, you will see and hear this switch catch.
  • The battery release switch is just to the inside of the battery and slides parallel to it.
  • Push the switch to the side. It is not just an open or close switch, it actually pops the battery up so you will feel some resistance.
  • When inserting a battery back into the device, you do not need to touch this switch. Just press the battery firmly down, you will see and hear this switch catch.
Kits RAM pour Mac
Accélérez votre Mac. Maximisez sa mémoire.
Kits RAM pour Mac
Augmentez la mémoire de votre Mac.
Pull the battery up and out. Use a plastic opening tool if necessary. Pull the battery up and out. Use a plastic opening tool if necessary. Pull the battery up and out. Use a plastic opening tool if necessary.
  • Pull the battery up and out. Use a plastic opening tool if necessary.
Using the Phillips #1 screwdriver, remove the nine 7mm screws holding the top panel. Flip device right side up and open it.
  • Using the Phillips #1 screwdriver, remove the nine 7mm screws holding the top panel.
  • Flip device right side up and open it.
Lift the top panel up, rotating forward onto the keyboard. Do not try to remove yet, cables are still attached. Do not try to remove yet, cables are still attached.
  • Lift the top panel up, rotating forward onto the keyboard.
  • Do not try to remove yet, cables are still attached.
Lift the black latch on each connection securing the cables. Pull the cable free.
  • Lift the black latch on each connection securing the cables.
  • Pull the cable free.
Lift the keyboard up by the center of the back. You may need a plastic tool such as the black plastic spudger to get under the edge. Lift up, pulling the edges from under the top cover, and lay down  on the front of the device. Do not pull away, there is still a cable connecting the keyboard.
  • Lift the keyboard up by the center of the back. You may need a plastic tool such as the black plastic spudger to get under the edge.
  • Lift up, pulling the edges from under the top cover, and lay down on the front of the device.
  • Do not pull away, there is still a cable connecting the keyboard.
Lift the black clasp holding the cable. Pull the cable free.
  • Lift the black clasp holding the cable.
  • Remove the keyboard.
William Michaud
Membre depuis le 20/03/2018
337 Réputation
3 tutoriels rédigés
Équipe
UMass Dartmouth, Team S5-G6, Peak Spring 2018 Membre de l'équipe UMass Dartmouth, Team S5-G6, Peak Spring 2018
UMASSD-PEAK-S18S5G6
3 membres
8 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 3
Total : 33
