Introduction
This guide will show how to remove and replace the hard drive of an Acer 583P-9688.
Remove the 18 marked screws (2.12 mm) using a Phillips #1 head screwdriver.
  • Remove the 18 marked screws (2.12 mm) using a Phillips #1 head screwdriver.
Ajouter un commentaire
Mac RAM Kits
Speed up your Mac. Max out its memory.
Mac RAM Kits
Get more memory out of your Mac.
Use the spudger to slowly work your way around the perimeter starting at the marked location to pop the bottom cover off. Use the spudger to slowly work your way around the perimeter starting at the marked location to pop the bottom cover off.
  • Use the spudger to slowly work your way around the perimeter starting at the marked location to pop the bottom cover off.
This particular laptop does not have a hard drive. The red rectangle is where your hard drive will be. To remove the hard drive, carefully take it out of the brackets holding it in place. Once you have it out of the brackets, remove the connector from the hard drive.
  • This particular laptop does not have a hard drive. The red rectangle is where your hard drive will be.
  • To remove the hard drive, carefully take it out of the brackets holding it in place. Once you have it out of the brackets, remove the connector from the hard drive.
2 autre(s) ont terminé cette réparation.
Collin Steel
Membre depuis le 29/01/2018
307 Réputation
2 tutoriels rédigés
Équipe
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 3
30 derniers jours : 12
Total : 44
