Introduction
In this guide, you will be replacing the power jack, which is independently secured without the use of any internal screws.
Pièces
Aucune pièce nécessaire.
Use a Phillips #1 screwdriver to remove all eighteen 2.12 mm screws from the back plate of your Acer Aspire.
  • Use a Phillips #1 screwdriver to remove all eighteen 2.12 mm screws from the back plate of your Acer Aspire.
Ajouter un commentaire
Use the spudger to remove the back plate in the highlighted area to carefully pop out the back plate. Use the spudger to remove the back plate in the highlighted area to carefully pop out the back plate.
  • Use the spudger to remove the back plate in the highlighted area to carefully pop out the back plate.
Unplug the power jack from the receptor port on the motherboard, highlighted in red. Remove the power jack from designated area on the side of the computer, highlighted in orange.
  • Unplug the power jack from the receptor port on the motherboard, highlighted in red.
  • Remove the power jack from designated area on the side of the computer, highlighted in orange.
2 autre(s) ont terminé cette réparation.
Joey Freeman
Membre depuis le 29/01/2018
224 Réputation
1 tutoriel rédigé
Équipe
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 1
Total : 37
