Introduction
In this guide you will learn how to replace the RAM in an Acer Aspire M5-583P-9688 laptop.
Remove all 18 marked screws (2.12 mm) using a Phillips #1 screwdriver.
  • Remove all 18 marked screws (2.12 mm) using a Phillips #1 screwdriver.
Ajouter un commentaire
Mac RAM Kits
Speed up your Mac. Max out its memory.
Mac RAM Kits
Get more memory out of your Mac.
Use the spudger to slowly work your way around the perimeter starting at the marked location to pop the bottom cover off. Use the spudger to slowly work your way around the perimeter starting at the marked location to pop the bottom cover off.
  • Use the spudger to slowly work your way around the perimeter starting at the marked location to pop the bottom cover off.
Pull back the brackets holding the RAM in place and remove the RAM. Be careful when pulling the brackets away from the RAM. Don't pull on them too much so they don't break.
  • Pull back the brackets holding the RAM in place and remove the RAM.
  • Be careful when pulling the brackets away from the RAM. Don't pull on them too much so they don't break.
2 autre(s) ont terminé cette réparation.
Collin Steel
Membre depuis le 29/01/2018
307 Réputation
2 tutoriels rédigés
Équipe
Voir les statistiques:
Dernières 24 heures : 1
7 derniers jours : 1
30 derniers jours : 3
Total : 44
