Aller au contenu principal
Acer Aspire S7-392-6484 Battery Replacement
Ce dont vous avez besoin
  1. Acer Aspire S7-392-6484 Battery Replacement, Battery: étape 1, image 1 de 2 Acer Aspire S7-392-6484 Battery Replacement, Battery: étape 1, image 2 de 2
    • Remove all marked 3mm screws from the back panel of the device using a T6 Torx screwdriver.
    • Remove the orange marked screws using a T6 Torx screwdriver. Note that these screws are 4mm in length.
    • After all marked screws have been removed, lift up back panel to expose internal parts.
  2. Acer Aspire S7-392-6484 Battery Replacement: étape 2, image 1 de 1
    • Unscrew the marked 1.5 mm screws with a Phillips #01 screwdriver.
  3. Acer Aspire S7-392-6484 Battery Replacement: étape 3, image 1 de 1
    • Disconnect the cable located at the top of the battery. Be careful to pull the cable horizontally, not vertically.
  4. Acer Aspire S7-392-6484 Battery Replacement: étape 4, image 1 de 1
    • Remove the battery.
Nicholas Wise
Membre depuis le 02/14/18
754 Réputation
5 tutoriels rédigés
Équipe
USF Tampa, Team S2-G6, Eyestone Spring 2018 Membre de l'équipe USF Tampa, Team S2-G6, Eyestone Spring 2018
USFT-EYESTONE-S18S2G6
3 membres
5 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 4
30 derniers jours : 26
Total : 5,428
