Introduction
If the tablet and keyboard of your device are not connecting properly, then you may need to replace the docking connectors on your device. Before attempting to replace the docking connectors, please visit the troubleshooting page, follow the directions under the heading Keyboard Does Not Dock Properly, and attempt any recommendations listed. If you have followed all of the instructions on the troubleshooting page and still have sporadic or non-existent communication between the tablet and keyboard, you can follow this guide to replace the docking connectors on your device.
Pièces
Aucune pièce nécessaire.
Remove the 8, 5.25 mm screws on the back cover using the screwdriver. Insert the opening tool into the USB port. Carefully remove the back cover using the opening tool.
  • Remove the 8, 5.25 mm screws on the back cover using the screwdriver.
  • Insert the opening tool into the USB port.
  • Carefully remove the back cover using the opening tool.
Ajouter un commentaire
Remove the yellow tape from the board cables. Carefully unplug the two board cables from their connectors by pulling on them. Carefully unplug the two board cables from their connectors by pulling on them.
  • Remove the yellow tape from the board cables.
  • Carefully unplug the two board cables from their connectors by pulling on them.
Remove the 2, 4.25 mm screws on the left hand tab that are securing the dock in place. Remove the 2, 4.25 mm screws on the left hand tab that are securing the dock in place.
  • Remove the 2, 4.25 mm screws on the left hand tab that are securing the dock in place.
Mac RAM Kits
Speed up your Mac. Max out its memory.
Mac RAM Kits
Get more memory out of your Mac.
Lift up the metal tab on the left side using the opening tool. Using your fingers may be easier than using the opening tool for this particular step, although both can be used. Using your fingers may be easier than using the opening tool for this particular step, although both can be used.
  • Lift up the metal tab on the left side using the opening tool.
  • Using your fingers may be easier than using the opening tool for this particular step, although both can be used.
Remove the 2, 4.25 mm screws on the right hand tab that are securing the dock in place. Remove the 2, 4.25 mm screws on the right hand tab that are securing the dock in place.
  • Remove the 2, 4.25 mm screws on the right hand tab that are securing the dock in place.
Lift the metal tab on the right side up using the opening tool. Using your fingers may be easier than using the opening tool for this particular step, although both can be used. Using your fingers may be easier than using the opening tool for this particular step, although both can be used.
  • Lift the metal tab on the right side up using the opening tool.
Insert the opening tool between the two sections of the device. Lift up the keyboard section using the opening tool.
  • Insert the opening tool between the two sections of the device.
  • Lift up the keyboard section using the opening tool.
Carefully pull up on the keyboard section using your hands to remove it from the screen section. Carefully pull up on the keyboard section using your hands to remove it from the screen section. Carefully pull up on the keyboard section using your hands to remove it from the screen section.
  • Carefully pull up on the keyboard section using your hands to remove it from the screen section.
Pull the docking connector off of the screen section. Pull the docking connector off of the screen section. Pull the docking connector off of the screen section.
  • Pull the docking connector off of the screen section.
Grecia Corrada
Membre depuis le 19/03/2018
1 013 Réputation
6 tutoriels rédigés
Équipe
Baylor, Team S3-G3, Williams Spring 2018 Membre de l'équipe Baylor, Team S3-G3, Williams Spring 2018
BU-WILLIAMS-S18S3G3
3 membres
6 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 3
7 derniers jours : 3
30 derniers jours : 7
Total : 64
