Introduction
If your trackpad is not functioning properly or responding, you may need to replace the trackpad. Before attempting to replace the trackpad, please visit the troubleshooting page and follow any recommendations. The troubleshooting page recommends that you update the trackpad drivers and attempt to disable and enable the trackpad to see if it fixes the problem. If the trackpad is still not responding, please follow the steps below to replace the trackpad.
Pièces
Aucune pièce nécessaire.
Remove the 8, 5.25 mm screws on the back cover using the screwdriver. Insert the opening tool into the USB port. Carefully remove the back cover with the opening tool.
  • Remove the 8, 5.25 mm screws on the back cover using the screwdriver.
  • Insert the opening tool into the USB port.
  • Carefully remove the back cover with the opening tool.
Ajouter un commentaire
Lift up on the ZIF connector that secures the ribbon cable using the opening tool. Pull the ribbon cable free. Pull the ribbon cable free.
  • Lift up on the ZIF connector that secures the ribbon cable using the opening tool.
  • Pull the ribbon cable free.
Kits RAM pour Mac
Accélérez votre Mac. Maximisez sa mémoire.
Kits RAM pour Mac
Augmentez la mémoire de votre Mac.
Remove the 4, 2.5 mm screws from the trackpad cover. Remove the 4, 2.5 mm screws from the trackpad cover. Remove the 4, 2.5 mm screws from the trackpad cover.
  • Remove the 4, 2.5 mm screws from the trackpad cover.
Remove the metal piece that secures the trackpad cover in place using the opening tool. Remove the metal piece that secures the trackpad cover in place using the opening tool.
  • Remove the metal piece that secures the trackpad cover in place using the opening tool.
Remove the trackpad using the opening tool and your hands. Remove the trackpad using the opening tool and your hands. Remove the trackpad using the opening tool and your hands.
  • Remove the trackpad using the opening tool and your hands.
Grecia Corrada
Membre depuis le 19/03/2018
1 013 Réputation
6 tutoriels rédigés
Équipe
Baylor, Team S3-G3, Williams Spring 2018 Membre de l'équipe Baylor, Team S3-G3, Williams Spring 2018
BU-WILLIAMS-S18S3G3
3 membres
6 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 6
Total : 54
