Introduction
If a USB device is plugged-in correctly into the USB port and the Acer Aspire Switch 10 does not detect the USB device, then you may need to replace the USB port. Before you attempt to replace the USB port, please make sure that you have visited the troubleshooting page and followed the recommendations on the page. The troubleshooting page recommends that you make sure the USB device itself is working properly and that the USB port is clean. If you have attempted everything that the troubleshooting page recommends and the USB port still is not working properly, this guide will help you replace the USB port.
Pièces
Aucune pièce nécessaire.
Remove the 8, 5.25 mm screws on the back cover using the screwdriver. Carefully remove the back cover using the opening tool. Carefully remove the back cover using the opening tool.
  • Remove the 8, 5.25 mm screws on the back cover using the screwdriver.
  • Carefully remove the back cover using the opening tool.
Ajouter un commentaire
Remove the yellow tape from the circuit board that is connected to the USB port. Carefully unplug the two bundled cable connectors by pulling on them. Carefully unplug the two bundled cable connectors by pulling on them.
  • Remove the yellow tape from the circuit board that is connected to the USB port.
  • Carefully unplug the two bundled cable connectors by pulling on them.
Flip up the ZIF connector that holds the larger ribbon cable in place with the opening tool. Carefully unplug the larger ribbon cable by pulling on its blue tab. Carefully unplug the larger ribbon cable by pulling on its blue tab.
  • Flip up the ZIF connector that holds the larger ribbon cable in place with the opening tool.
  • Carefully unplug the larger ribbon cable by pulling on its blue tab.
Idées cadeaux pour la Fête des Pères
Mettons nos papas à l’honneur ainsi que nos mentors qui nous ont appris à réparer.
Honorons ceux qui nous ont enseigné à réparer.
Flip up the small ZIF connector that holds the smaller ribbon cable in place with the opening tool. Carefully unplug the smaller ribbon cable by pulling on its blue tab. Carefully unplug the smaller ribbon cable by pulling on its blue tab.
  • Flip up the small ZIF connector that holds the smaller ribbon cable in place with the opening tool.
  • Carefully unplug the smaller ribbon cable by pulling on its blue tab.
Remove the 3, 2.5 mm screws on the circuit board. Remove the 3, 2.5 mm screws on the circuit board. Remove the 3, 2.5 mm screws on the circuit board.
  • Remove the 3, 2.5 mm screws on the circuit board.
Remove the 2, 4.25 mm screws on the security tab. Remove the 2, 4.25 mm screws on the security tab.
  • Remove the 2, 4.25 mm screws on the security tab.
Lift the security tab so that it will be out of the way when you remove the circuit board. Using your fingers may be easier than using the opening tool for this particular step, although both can be used. Using your fingers may be easier than using the opening tool for this particular step, although both can be used.
  • Lift the security tab so that it will be out of the way when you remove the circuit board.
  • Using your fingers may be easier than using the opening tool for this particular step, although both can be used.
Remove the circuit board by lifting it up with the opening tool. The USB port is attached to this circuit board you have just removed. To replace the USB port on this piece, please go to the page How To Solder and Desolder Connections. The USB port is attached to this circuit board you have just removed. To replace the USB port on this piece, please go to the page How To Solder and Desolder Connections.
  • Remove the circuit board by lifting it up with the opening tool.
  • The USB port is attached to this circuit board you have just removed. To replace the USB port on this piece, please go to the page How To Solder and Desolder Connections.
Grecia Corrada
Membre depuis le 19/03/2018
1 013 Réputation
6 tutoriels rédigés
Équipe
Baylor, Team S3-G3, Williams Spring 2018 Membre de l'équipe Baylor, Team S3-G3, Williams Spring 2018
BU-WILLIAMS-S18S3G3
3 membres
6 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 5
Total : 105
