Introduction
USB is essential on modern laptops. Use this guide to fix your broken ports.
Locate and remove the two 5.3 mm Phillips #1 screws holding the back panel in place.
  • Locate and remove the two 5.3 mm Phillips #1 screws holding the back panel in place.
Ajouter un commentaire
Use a spudger to pry the panel up from the laptop case and remove it. The laptop should now be open with the RAM and wifi chip now accessible.
  • Use a spudger to pry the panel up from the laptop case and remove it.
  • The laptop should now be open with the RAM and wifi chip now accessible.
Locate the wifi chip.
  • Locate the wifi chip.
Remove the 5 mm Phillips #1 screw holding the wifi chip in place. Carefully remove the wifi chip.
  • Remove the 5 mm Phillips #1 screw holding the wifi chip in place.
  • Carefully remove the wifi chip.
Remove the 8, 9 mm Phillips #1 screws holding the panel in place.
  • Remove the 8, 9 mm Phillips #1 screws holding the panel in place.
Flip the computer over, and with a spudger, remove the black panel directly below the keyboard. Remove the panel and flip it up onto the keyboard
  • Flip the computer over, and with a spudger, remove the black panel directly below the keyboard.
  • Remove the panel and flip it up onto the keyboard
With the panel removed, locate the USB port ribbon cable connecting to the motherboard. Carefully disconnect the ribbon cable.
  • With the panel removed, locate the USB port ribbon cable connecting to the motherboard.
  • Carefully disconnect the ribbon cable.
Unscrew the 5 mm Phillips #1 screw holding the USB ports in place.
  • Unscrew the 5 mm Phillips #1 screw holding the USB ports in place.
The USB ports can now be removed from the laptop.
  • The USB ports can now be removed from the laptop.
6 autre(s) ont terminé cette réparation.
Ryan Holland
Membre depuis le 15/04/2014
362 Réputation
2 tutoriels rédigés
Équipe
Cal Poly, Team 8-8, Regan Spring 2014 Membre de l'équipe Cal Poly, Team 8-8, Regan Spring 2014
CPSU-REGAN-S14S8G8
4 membres
7 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 3
7 derniers jours : 20
30 derniers jours : 79
Total : 3,212
