Pièces
Aucune pièce nécessaire.
Flipping your laptop over, the wifi card is located on the lower half of the laptop Remove the two screws  shown on diagram using a Phillips head screwdriver Use the opening tool to help lift and remove the lower case
  • Flipping your laptop over, the wifi card is located on the lower half of the laptop
  • Remove the two screws shown on diagram using a Phillips head screwdriver
  • Use the opening tool to help lift and remove the lower case
Ajouter un commentaire
Remove the screw that is securing the wifi card in place Remove the screw that is securing the wifi card in place
  • Remove the screw that is securing the wifi card in place
Mac RAM Kits
Speed up your Mac. Max out its memory.
Mac RAM Kits
Get more memory out of your Mac.
Use your fingers to gently pull out the wifi chip
  • Use your fingers to gently pull out the wifi chip
Disconnect the black and white wire from the wifi chip
  • Disconnect the black and white wire from the wifi chip
Erica Gomes
Membre depuis le 18/03/2018
369 Réputation
3 tutoriels rédigés
Équipe
UMass Dartmouth, Team S4-G6, Covino Spring 2018 Membre de l'équipe UMass Dartmouth, Team S4-G6, Covino Spring 2018
UMASSD-COVINO-S18S4G6
3 membres
5 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 3
30 derniers jours : 8
Total : 33
