Introduction
If your wireless connection is inconsistent or unresponsive the network card may be faulty. Use this guide to replace the network card and get back online.
Remove the nine 4mm screws with a PH0 screwdriver. Remove the two 6mm screws with a PH0 screwdriver.
  • Remove the nine 4mm screws with a PH0 screwdriver.
  • Remove the two 6mm screws with a PH0 screwdriver.
Ajouter un commentaire
Remove the black rubber tab on the back of the computer Remove the 4mm screw hidden underneath the black tab with a PH0 screwdriver.
  • Remove the black rubber tab on the back of the computer
  • Remove the 4mm screw hidden underneath the black tab with a PH0 screwdriver.
Orient the computer upside down, with the hinges facing away from you. Find the black plastic piece in the SD card slot on the right side of the computer.
  • Orient the computer upside down, with the hinges facing away from you.
  • Find the black plastic piece in the SD card slot on the right side of the computer.
  • Remove the plastic piece by sliding it out of the SD card slot.
Kits RAM pour Mac
Accélérez votre Mac. Maximisez sa mémoire.
Kits RAM pour Mac
Augmentez la mémoire de votre Mac.
Insert a spudger at these eight locations to disengage the plastic tabs from the housing cover, and pry apart. Continue around the entire perimeter of the cover with the spudger. Use a spudger to pry the cover around I/O ports.
  • Insert a spudger at these eight locations to disengage the plastic tabs from the housing cover, and pry apart.
    • Continue around the entire perimeter of the cover with the spudger.
  • Use a spudger to pry the cover around I/O ports.
Remove the two 4mm screws using a PH0 screwdriver. Depress the tabs holding the battery with a spudger. Disconnect the battery connector from the motherboard using a spudger.
  • Remove the two 4mm screws using a PH0 screwdriver.
  • Depress the tabs holding the battery with a spudger.
  • Disconnect the battery connector from the motherboard using a spudger.
  • Pull the battery up and away from the laptop to remove.
Remove the  wire connector from the network card using a plastic opening tool.
  • Remove the wire connector from the network card using a plastic opening tool.
Remove the 3mm Phillips #0 screw.
  • Remove the 3mm Phillips #0 screw.
Gently slide the network card out of the motherboard connector.
  • Gently slide the network card out of the motherboard connector.
Nat McCormick
Membre depuis le 15/02/2018
645 Réputation
5 tutoriels rédigés
Équipe
USF Tampa, Team S16-G1, Boczar Spring 2018 Membre de l'équipe USF Tampa, Team S16-G1, Boczar Spring 2018
USFT-BOCZAR-S18S16G1
5 membres
5 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 3
Total : 36
