Aller au contenu principal
Acer Aspire V5-552PG-X469 Battery Replacement
Ce dont vous avez besoin
  1. Acer Aspire V5-552PG-X469 Battery Replacement, Back Case: étape 1, image 1 de 1
    • Remove the storage tray on the left edge of the device.
  2. Acer Aspire V5-552PG-X469 Battery Replacement: étape 2, image 1 de 1
    • Use a Phillips #0 screwdriver to remove seventeen 7mm screws from the lower case.
  3. Acer Aspire V5-552PG-X469 Battery Replacement: étape 3, image 1 de 1
    • Lift up the back case to remove it.
  4. Acer Aspire V5-552PG-X469 Battery Replacement, Battery: étape 4, image 1 de 2 Acer Aspire V5-552PG-X469 Battery Replacement, Battery: étape 4, image 2 de 2
    • Pull the battery connector away from the hard drive to disconnect it from its socket.
  5. Acer Aspire V5-552PG-X469 Battery Replacement: étape 5, image 1 de 3 Acer Aspire V5-552PG-X469 Battery Replacement: étape 5, image 2 de 3 Acer Aspire V5-552PG-X469 Battery Replacement: étape 5, image 3 de 3
    • Pull the white connector toward the battery to disconnect it.
    • Pull the black tape-wrapped connector toward the battery to disconnect it.
  6. Acer Aspire V5-552PG-X469 Battery Replacement: étape 6, image 1 de 2 Acer Aspire V5-552PG-X469 Battery Replacement: étape 6, image 2 de 2
    • Remove the PH #0 screw from the center of the battery.
  7. Acer Aspire V5-552PG-X469 Battery Replacement: étape 7, image 1 de 2 Acer Aspire V5-552PG-X469 Battery Replacement: étape 7, image 2 de 2
    • Lift up the battery to remove it.
    • Be careful not to bend the battery while lifting it out, as this may cause a fire hazard.
Rebecca Aseo
Membre depuis le 09/20/17
304 Réputation
3 tutoriels rédigés
Équipe
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 8
30 derniers jours : 10
Total : 1,248
