Aller au contenu principal
Acer Aspire V5-572, V5-572G HDD Replacement
Ce dont vous avez besoin
Vidéo d'introduction
  1. Acer Aspire V5-572, V5-572G HDD Replacement, Bottom Cover: étape 1, image 1 de 1
    • Switch-off the Laptop.
    • Remove the seventeen Philips #0 screws.
  2. Acer Aspire V5-572, V5-572G HDD Replacement: étape 2, image 1 de 1
    • If there is a plastic storage tray in the laptop, remove it.
  3. Acer Aspire V5-572, V5-572G HDD Replacement: étape 3, image 1 de 3 Acer Aspire V5-572, V5-572G HDD Replacement: étape 3, image 2 de 3 Acer Aspire V5-572, V5-572G HDD Replacement: étape 3, image 3 de 3
    • Starting from the SD Memory Card hole, start prying between the top and bottom cases.
    • Use plastic tools to avoid damaging the cover.
    • Remove the bottom case.
  4. Acer Aspire V5-572, V5-572G HDD Replacement: étape 4, image 1 de 1
    • Disconnect the battery immediately for a safer repair.
    • Pull the battery connector away from the hard drive to disconnect it.
  5. Acer Aspire V5-572, V5-572G HDD Replacement, HDD: étape 5, image 1 de 3 Acer Aspire V5-572, V5-572G HDD Replacement, HDD: étape 5, image 2 de 3 Acer Aspire V5-572, V5-572G HDD Replacement, HDD: étape 5, image 3 de 3
    • Disconnect the SATA Cable from the Mother Board.
    • Take out the HDD and remove the SATA cable from it.
    • Now you can change / upgrade your HDD.
3 autres ont terminé cette réparation.
ZFix
Membre depuis le 12/09/13
191 368 Réputation
330 tutoriels rédigés
Équipe
Master Techs Membre de l'équipe Master Techs
Community
321 membres
1 468 tutoriels rédigés
7 commentaires
Thank you very much for the tutorial, it was a 12 minute job ☺️And extremely pleased with the new ssd its incredible
Best Regards
Luckystyx - Réponse
Thank you so much for the extremely easy tutorial and it definitely only took 2 minutes longer (12 minutes)
Your site is invaluable, Keep up the great work and all that you do,
5 star rating for you guys..
Kindest Regards
@Styx
Luckystyx - Réponse
So the original hdd came in with the win 7 and it was later upgraded to win 10 for free. If i change it to ssd would i be able to get on it my original copy of win 7 and will it upgrade to win 10?
ashmir - Réponse
ashmir, you just clone your HDD with a free software such as Macrium Reflect and don’t need to worry about installing everything from zero!!!
Miguel Rodríguez - Réponse
Thank you for the tutorial.
But need a clarification. If i have a faulty hard disc it starts up but it freezes after 20 minutes.
Is it still possible to clone it.
Also if i change the hard drive do I need to install any software or the bios all over again.
Your inputs will be appreciated.
olatunji.jimoh - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 30
30 derniers jours : 126
Total : 17,745
