Aller au contenu principal
Acer Aspire V5-572, V5-572G Mainboard Replacement
Ce dont vous avez besoin
Vidéo d'introduction
  1. Acer Aspire V5-572, V5-572G Mainboard Replacement, Bottom Cover: étape 1, image 1 de 1
    • Switch-off the Laptop.
    • Remove the seventeen Philips #0 screws.
  2. Acer Aspire V5-572, V5-572G Mainboard Replacement: étape 2, image 1 de 1
    • If there is a plastic storage tray in the laptop, remove it.
  3. Acer Aspire V5-572, V5-572G Mainboard Replacement: étape 3, image 1 de 3 Acer Aspire V5-572, V5-572G Mainboard Replacement: étape 3, image 2 de 3 Acer Aspire V5-572, V5-572G Mainboard Replacement: étape 3, image 3 de 3
    • Starting from the SD Memory Card hole, start prying between the top and bottom cases.
    • Use plastic tools to avoid damaging the cover.
    • Remove the bottom case.
  4. Acer Aspire V5-572, V5-572G Mainboard Replacement: étape 4, image 1 de 1
    • Disconnect the battery immediately for a safer repair.
    • Pull the battery connector away from the hard drive to disconnect it.
  5. Acer Aspire V5-572, V5-572G Mainboard Replacement, Battery: étape 5, image 1 de 1
    • Remove the single Phillips 0 screw securing the battery.
  6. Acer Aspire V5-572, V5-572G Mainboard Replacement: étape 6, image 1 de 1
    • Remove the battery
  7. Acer Aspire V5-572, V5-572G Mainboard Replacement, HDD: étape 7, image 1 de 3 Acer Aspire V5-572, V5-572G Mainboard Replacement, HDD: étape 7, image 2 de 3 Acer Aspire V5-572, V5-572G Mainboard Replacement, HDD: étape 7, image 3 de 3
    • Disconnect the SATA Cable from the Mother Board.
    • Take out the HDD and remove the SATA cable from it.
    • Now you can change / upgrade your HDD.
  8. Acer Aspire V5-572, V5-572G Mainboard Replacement, Wi-Fi half mini PCIe card: étape 8, image 1 de 3 Acer Aspire V5-572, V5-572G Mainboard Replacement, Wi-Fi half mini PCIe card: étape 8, image 2 de 3 Acer Aspire V5-572, V5-572G Mainboard Replacement, Wi-Fi half mini PCIe card: étape 8, image 3 de 3
    • Remove 1x screw and disconnect the two antenna coaxial cables.
    • Remove the Wi-Fi card from the slot.
  9. Acer Aspire V5-572, V5-572G Mainboard Replacement, Cooling / Fan System: étape 9, image 1 de 2 Acer Aspire V5-572, V5-572G Mainboard Replacement, Cooling / Fan System: étape 9, image 2 de 2
    • Disconnect the Fan cable.
    • Remove the three screws from the CPU cooler and one from the Fan module.
    • When you change the Cooling system, you must clean the processor from old thermal compound and put new.
  10. Acer Aspire V5-572, V5-572G Mainboard Replacement, Mainboard: étape 10, image 1 de 3 Acer Aspire V5-572, V5-572G Mainboard Replacement, Mainboard: étape 10, image 2 de 3 Acer Aspire V5-572, V5-572G Mainboard Replacement, Mainboard: étape 10, image 3 de 3
    • Disconnect one by one:
    • LCD Display flex cable
    • DC Jack cable
    • USB Board flex cable
    • Touch pad flex cable
    • Keyboard flex cable
  11. Acer Aspire V5-572, V5-572G Mainboard Replacement: étape 11, image 1 de 3 Acer Aspire V5-572, V5-572G Mainboard Replacement: étape 11, image 2 de 3 Acer Aspire V5-572, V5-572G Mainboard Replacement: étape 11, image 3 de 3
    • Disconnect the Loudspeakers and the Microphone cables.
    • Remove 6x Phillips screws, 3x from the Main board and 3x from the hinge.
    • Open a little the laptop to open the hinge.
    • By hand, open the hinge to the end.
  12. Acer Aspire V5-572, V5-572G Mainboard Replacement: étape 12, image 1 de 3 Acer Aspire V5-572, V5-572G Mainboard Replacement: étape 12, image 2 de 3 Acer Aspire V5-572, V5-572G Mainboard Replacement: étape 12, image 3 de 3
    • Carefully remove the the Main board.
ZFix
Membre depuis le 12/09/13
191 055 Réputation
330 tutoriels rédigés
Équipe
Master Techs Membre de l'équipe Master Techs
Community
322 membres
2 506 tutoriels rédigés
Un commentaire
where did you find your motherboard replacement? Or whats model is it? I need to replace my mb but cant find any online for sale.
Ruby - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 5
30 derniers jours : 22
Total : 4,625
