Introduction
This guide will provide you with simple and clear steps on how to remove the fan on your Acer Chromebook C720-2420.
Place your Chromebook upside down. Utilizing the precision magnetized Phillips #0 screwdriver, remove all thirteen 6.5 mm Phillips screws that secure the back cover.
  • Place your Chromebook upside down.
  • Utilizing the precision magnetized Phillips #0 screwdriver, remove all thirteen 6.5 mm Phillips screws that secure the back cover.
  • Before doing anything, make sure your Acer Chromebook is completely turned off.
Ajouter un commentaire
Use the plastic opening tool to carefully remove the bottom.
  • Use the plastic opening tool to carefully remove the bottom.
Remove the two 3.6 mm Phillips screws holding the battery in place. Remove the two 3.6 mm Phillips screws holding the battery in place.
  • Remove the two 3.6 mm Phillips screws holding the battery in place.
Kits RAM pour Mac
Accélérez votre Mac. Maximisez sa mémoire.
Kits RAM pour Mac
Augmentez la mémoire de votre Mac.
Disconnect the connector that attaches the battery to the Chromebook with a pair of pliers or tweezers. Alternatively, you could use your hands, as it may be difficult to unhook the connector.
  • Disconnect the connector that attaches the battery to the Chromebook with a pair of pliers or tweezers.
    • Alternatively, you could use your hands, as it may be difficult to unhook the connector.
Remove the battery.
  • Remove the battery.
Remove the six 4.7 mm Phillips screws that secure the fan. Remove the six 4.7 mm Phillips screws that secure the fan.
  • Remove the six 4.7 mm Phillips screws that secure the fan.
Disconnect these cables from the motherboard using the tweezers. Alternatively, you may use your hands. Pull out the fan.
  • Disconnect these cables from the motherboard using the tweezers.
    • Alternatively, you may use your hands.
  • Pull out the fan.
Jessica Beckford
Membre depuis le 12/02/2018
494 Réputation
4 tutoriels rédigés
Équipe
USF Tampa, Team S15-G4, Boczar Spring 2018 Membre de l'équipe USF Tampa, Team S15-G4, Boczar Spring 2018
USFT-BOCZAR-S18S15G4
4 membres
6 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 3
Total : 38
