Introduction
This guide will show you how to change the Solid State Drive in Acer Chromebook C740-C4PE.
Pièces
Aucune pièce nécessaire.
Make sure the laptop is turned off and laid down on a flat surface. Unscrew the 13 screws on the back of the device using a PH0 Phillips head screwdriver. Use the spudger or any other prying tool to pry the back plate off of the device.
  • Make sure the laptop is turned off and laid down on a flat surface.
  • Unscrew the 13 screws on the back of the device using a PH0 Phillips head screwdriver.
  • Use the spudger or any other prying tool to pry the back plate off of the device.
  • Be sure not to pry too hard as it may result in snapping the back plate.
Ajouter un commentaire
Kits RAM pour Mac
Accélérez votre Mac. Maximisez sa mémoire.
Kits RAM pour Mac
Augmentez la mémoire de votre Mac.
Remove the 3.75 mm screw with a Phillips #0 screwdriver. Remove the 3.75 mm screw with a Phillips #0 screwdriver. Remove the 3.75 mm screw with a Phillips #0 screwdriver.
  • Remove the 3.75 mm screw with a Phillips #0 screwdriver.
Pull the Solid State Drive out of the connector.
  • Pull the Solid State Drive out of the connector.
Sang Huynh
Membre depuis le 08/03/2017
222 Réputation
2 tutoriels rédigés
Équipe
UMass Dartmouth, Team S6-G4, Rockett Fall 2017 Membre de l'équipe UMass Dartmouth, Team S6-G4, Rockett Fall 2017
UMASSD-ROCKETT-F17S6G4
3 membres
6 tutoriels rédigés
There are 2 types of SSD drives, m-SATA and M.2. Which does C740 use?
Guy Scree - Réponse
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 3
Total : 40
