Introduction
There are many reasons to replace your hard drive. You may be running out of storage space or want to upgrade to a solid state drive. Perhaps you are encountering errors with your data. This guide will get you fixed up in no time.
Ensure the laptop is powered down prior to beginning.
  • Ensure the laptop is powered down prior to beginning.
  • Turn the laptop over with the battery closest to your body.
  • The battery release is just above the left side of the battery.
Ajouter un commentaire
Insert a small tipped screwdriver or similar tool into the release. Gently slide the release all the way to the left.
  • Insert a small tipped screwdriver or similar tool into the release.
  • Gently slide the release all the way to the left.
  • You should hear a sound after the slide is all the way left. This lets you know the battery has disengaged.
With your hands on each end of the battery, carefully pull towards your body to remove. With your hands on each end of the battery, carefully pull towards your body to remove.
  • With your hands on each end of the battery, carefully pull towards your body to remove.
Using a #0 Phillips screwdriver, remove a total of eighteen identical 8mm Phillips  screws and set them aside.
  • Using a #0 Phillips screwdriver, remove a total of eighteen identical 8mm Phillips screws and set them aside.
Rotate the laptop 180 degrees so that the battery compartment is now furthest away from your body.
  • Rotate the laptop 180 degrees so that the battery compartment is now furthest away from your body.
Turn the laptop over so that you can easily open the screen to a vertical position.
  • Turn the laptop over so that you can easily open the screen to a vertical position.
Put your fingers under the top of the keyboard assembly directly below the Acer logo.
  • Put your fingers under the top of the keyboard assembly directly below the Acer logo.
  • Carefully pull up on the center until you hear the tabs disengage from the bottom.
Work your way around the seam with the plastic opening tool carefully prying the base and top cover apart. If you have difficulty with the plastic opening tool, use a metal spudger but be more cautious to not damage or mar your laptop case. If you have difficulty with the plastic opening tool, use a metal spudger but be more cautious to not damage or mar your laptop case.
  • Work your way around the seam with the plastic opening tool carefully prying the base and top cover apart.
  • If you have difficulty with the plastic opening tool, use a metal spudger but be more cautious to not damage or mar your laptop case.
When the two halves are separated, carefully lift up the front of the keyboard and touchpad assembly.
  • When the two halves are separated, carefully lift up the front of the keyboard and touchpad assembly.
  • You will see three ribbon cables attached to the motherboard.
Closest to the ribbon cable on the zero insertion force (ZIF) connector is a white locking tab. Carefully lift up on the locking tab with the plastic opening tool to release the ribbon cable. (Picture 2) Remove the ribbon cable from the connector.
  • Closest to the ribbon cable on the zero insertion force (ZIF) connector is a white locking tab.
  • Carefully lift up on the locking tab with the plastic opening tool to release the ribbon cable. (Picture 2)
  • Remove the ribbon cable from the connector.
Closest to the ribbon cable on the ZIF connector is a black locking tab. Carefully lift up on the locking tab with the plastic opening tool to release the ribbon cable. (Picture 2) Remove the ribbon cable from the connector.
  • Closest to the ribbon cable on the ZIF connector is a black locking tab.
On each side of the large connector there are two white tabs. Carefully push away from you with the plastic opening tool on each white tab to release the cable. (Picture 2) Remove the ribbon cable from the connector.
  • On each side of the large connector there are two white tabs.
  • Carefully push away from you with the plastic opening tool on each white tab to release the cable. (Picture 2)
Once all three ribbon cables are disconnected, lift off the top cover with the keyboard and touchpad. Once all three ribbon cables are disconnected, lift off the top cover with the keyboard and touchpad. Once all three ribbon cables are disconnected, lift off the top cover with the keyboard and touchpad.
  • Once all three ribbon cables are disconnected, lift off the top cover with the keyboard and touchpad.
The hard drive and carriage are at the lower right of the laptop. Using the plastic opening tool, carefully lift up on the black locking tab of the ZIF connector to release the USB port ribbon cable.
  • The hard drive and carriage are at the lower right of the laptop.
  • Using the plastic opening tool, carefully lift up on the black locking tab of the ZIF connector to release the USB port ribbon cable.
  • Move the USB port ribbon cable out of the way
Using a #0 Phillips screwdriver, remove the two 4mm screws securing the hard drive carriage in place. Using a #0 Phillips screwdriver, remove the two 4mm screws securing the hard drive carriage in place.
  • Using a #0 Phillips screwdriver, remove the two 4mm screws securing the hard drive carriage in place.
Hold the right side of the laptop in place with your right hand.
  • Hold the right side of the laptop in place with your right hand.
  • Put the fingers of your left hand along the top edge of the hard drive carriage.
  • Push the hard drive carriage towards your right hand to disconnect it from the motherboard.
  • This procedure may require more force then other procedures.
Lift up on the edge of the hard drive carriage closest to your body to remove the carriage. If doing the motherboard replacement guide, skip the next step.
  • Lift up on the edge of the hard drive carriage closest to your body to remove the carriage.
  • If doing the motherboard replacement guide, skip the next step.
There are two 3mm Phillips screws holding the hard drive into the carriage. One on either side of the carriage. Hold the hard drive carriage with your non-dominant hand along one side. Ensure one of the Phillips screws is visible. Using a #0 Phillips screwdriver, remove the 3mm screw to release the side of the hard drive from the carriage.
  • There are two 3mm Phillips screws holding the hard drive into the carriage. One on either side of the carriage.
  • Hold the hard drive carriage with your non-dominant hand along one side. Ensure one of the Phillips screws is visible.
  • Using a #0 Phillips screwdriver, remove the 3mm screw to release the side of the hard drive from the carriage.
  • Repeat the two previous procedures to remove the second 3mm Phillips screw freeing the hard drive from the carriage.
Aaron Weissman
Membre depuis le 23/10/2017
701 Réputation
8 tutoriels rédigés
Équipe
UMass Dartmouth, Team S3-G8, Bailey Fall 2017 Membre de l'équipe UMass Dartmouth, Team S3-G8, Bailey Fall 2017
UMASSD-BAILEY-F17S3G8
3 membres
8 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 6
Total : 48
