Introduction
How to open the tablet and replace the battery pack.
This video is for replacing the touch screen and LCD display but in the beginning you can see how to open the back cover and how to separate the battery from the tablet. You don't need to remove the mother board.
Please SUBSCRIBE to my channel ツ
Vidéo d'introduction
Switch-off the tablet. If you have a memory card inside, don't forget to remove it! Use a cutter and a plastic tool to remove the back cover.
  • Switch-off the tablet.
  • If you have a memory card inside, don't forget to remove it!
  • Use a cutter and a plastic tool to remove the back cover.
Ajouter un commentaire
Disconnect the battery connector. The battery is stuck to the LCD metal frame with a double side adhesive tape. With a plastic tool carefully separate it . The battery is stuck to the LCD metal frame with a double side adhesive tape. With a plastic tool carefully separate it .
  • Disconnect the battery connector.
  • The battery is stuck to the LCD metal frame with a double side adhesive tape. With a plastic tool carefully separate it .
Li-on Batteri Pack, 3.8V, 2640mAh
ZFix
Membre depuis le 09/12/2013
150 298 Réputation
424 tutoriels rédigés
Équipe
Master Techs Membre de l'équipe Master Techs
Community
274 membres
713 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 6
7 derniers jours : 52
30 derniers jours : 220
Total : 15,902
