Aller au contenu principal
Acer Iconia B1-711 LCD Display Replacement
Ce dont vous avez besoin
Vidéo d'introduction
  1. Acer Iconia B1-711 LCD Display Replacement, Back Cover: étape 1, image 1 de 3 Acer Iconia B1-711 LCD Display Replacement, Back Cover: étape 1, image 2 de 3 Acer Iconia B1-711 LCD Display Replacement, Back Cover: étape 1, image 3 de 3
    • Switch-off the tablet.
    • Remove any SIM and/or Memory Card.
    • Start opening near to the Volume Up/Down buttons. It's more well to use a plastic opening tool to avoid damaging the cover.
    • When lifting the cover, be careful not to tear the Loudspeaker cable at the bottom right side.
    • Disconnect the Loudspeaker cable from the Logic board.
  2. Acer Iconia B1-711 LCD Display Replacement: étape 2, image 1 de 2 Acer Iconia B1-711 LCD Display Replacement: étape 2, image 2 de 2
    • Before doing anything, disconnect the battery.
  3. Acer Iconia B1-711 LCD Display Replacement, Battery: étape 3, image 1 de 2 Acer Iconia B1-711 LCD Display Replacement, Battery: étape 3, image 2 de 2
    • With a long plastic tool like a spudger, unstick the battery from the metal LCD shield.
    • Lithium Ion Battery Pack - 3.8V, 2710mAh
  4. Acer Iconia B1-711 LCD Display Replacement, Audio Jack Connector: étape 4, image 1 de 3 Acer Iconia B1-711 LCD Display Replacement, Audio Jack Connector: étape 4, image 2 de 3 Acer Iconia B1-711 LCD Display Replacement, Audio Jack Connector: étape 4, image 3 de 3
    • Unscrew 2x Philips screws
    • Disconnect and remove the Audio Jack Board flex cable.
    • Remove the board with the Audio Jack Connector.
  5. Acer Iconia B1-711 LCD Display Replacement, Camera: étape 5, image 1 de 3 Acer Iconia B1-711 LCD Display Replacement, Camera: étape 5, image 2 de 3 Acer Iconia B1-711 LCD Display Replacement, Camera: étape 5, image 3 de 3
    • Remove the Audio jack flex cable.
    • Remove the metal plate which is placed on the camera connector.
    • Disconnect the camera flex cable.
  6. Acer Iconia B1-711 LCD Display Replacement: étape 6, image 1 de 1
    • Remove the camera.
  7. Acer Iconia B1-711 LCD Display Replacement, Microphone: étape 7, image 1 de 3 Acer Iconia B1-711 LCD Display Replacement, Microphone: étape 7, image 2 de 3 Acer Iconia B1-711 LCD Display Replacement, Microphone: étape 7, image 3 de 3
    • Remove the tape from the microphone.
    • Disconnect the Microphone wires and remove the Microphone.
  8. Acer Iconia B1-711 LCD Display Replacement, Logic Board: étape 8, image 1 de 3 Acer Iconia B1-711 LCD Display Replacement, Logic Board: étape 8, image 2 de 3 Acer Iconia B1-711 LCD Display Replacement, Logic Board: étape 8, image 3 de 3
    • Remove the green rubber and disconnect the touch screen flex cable.
    • Disconnect the 4 coaxial antenna cables (Wi-Fi, GPS, 3G).
    • Carefully unstuck the metal folio from the LCD display flex cable.
    • Remove the 3x Phillips screws.
  9. Acer Iconia B1-711 LCD Display Replacement: étape 9, image 1 de 3 Acer Iconia B1-711 LCD Display Replacement: étape 9, image 2 de 3 Acer Iconia B1-711 LCD Display Replacement: étape 9, image 3 de 3
    • Lift the board from the side of the battery connector and turn it around the display connector on 360 degrees.
    • Be careful for the flex cable!
    • Disconnect the LCD display flex cable.
  10. Acer Iconia B1-711 LCD Display Replacement: étape 10, image 1 de 2 Acer Iconia B1-711 LCD Display Replacement: étape 10, image 2 de 2
    • This is the Logic board.
  11. Acer Iconia B1-711 LCD Display Replacement, LCD Display: étape 11, image 1 de 2 Acer Iconia B1-711 LCD Display Replacement, LCD Display: étape 11, image 2 de 2
    • Careful unstuck the metal folio from the screen shield.
    • Remove the 4x Phillips screws.
  12. Acer Iconia B1-711 LCD Display Replacement: étape 12, image 1 de 3 Acer Iconia B1-711 LCD Display Replacement: étape 12, image 2 de 3 Acer Iconia B1-711 LCD Display Replacement: étape 12, image 3 de 3
    • lift the screen shield from one side and open it like a door, then remove it.
  13. Acer Iconia B1-711 LCD Display Replacement: étape 13, image 1 de 3 Acer Iconia B1-711 LCD Display Replacement: étape 13, image 2 de 3 Acer Iconia B1-711 LCD Display Replacement: étape 13, image 3 de 3
    • The LCD display is held from the metal screen frame by several locking clips.
    • Very careful using a tool with sharp edge, release the screen from the one side.
  14. Acer Iconia B1-711 LCD Display Replacement: étape 14, image 1 de 3 Acer Iconia B1-711 LCD Display Replacement: étape 14, image 2 de 3 Acer Iconia B1-711 LCD Display Replacement: étape 14, image 3 de 3
    • Lift the display up and remove it.
2 autres ont terminé cette réparation.
ZFix
Membre depuis le 12/09/13
191 182 Réputation
330 tutoriels rédigés
Équipe
Master Techs Membre de l'équipe Master Techs
Community
322 membres
2 521 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 3
30 derniers jours : 6
Total : 2,335
