Aller au contenu principal
Acer Iconia B1-A71 LCD Display Replacement
Ce dont vous avez besoin
Vidéo d'introduction
  1. Acer Iconia B1-A71 LCD Display Replacement, Acer Iconia B1-A71 LCD Display Replacement: étape 1, image 1 de 3 Acer Iconia B1-A71 LCD Display Replacement, Acer Iconia B1-A71 LCD Display Replacement: étape 1, image 2 de 3 Acer Iconia B1-A71 LCD Display Replacement, Acer Iconia B1-A71 LCD Display Replacement: étape 1, image 3 de 3
    • Switch-off the tablet.
    • If you can't switch it off, use the reset button to do this.
    • With a cutter and a plastic tool remove the back cover.
    • If you have a memory card inside, don't forget to remove it!
  2. Acer Iconia B1-A71 LCD Display Replacement: étape 2, image 1 de 2 Acer Iconia B1-A71 LCD Display Replacement: étape 2, image 2 de 2
    • First, disconnect the battery.
    • Now, disconnect the loudspeaker and remove the back cover.
    • Remove all scotch tapes and disconnect the touch screen flex cable...
    • LCD display flex cable,
    • the microphone,
    • and the WiFi and Bluetooth antennas flex cables.
  3. Acer Iconia B1-A71 LCD Display Replacement: étape 3, image 1 de 3 Acer Iconia B1-A71 LCD Display Replacement: étape 3, image 2 de 3 Acer Iconia B1-A71 LCD Display Replacement: étape 3, image 3 de 3
    • Unscrew 5x screws and rmove the main board.
  4. Acer Iconia B1-A71 LCD Display Replacement: étape 4, image 1 de 3 Acer Iconia B1-A71 LCD Display Replacement: étape 4, image 2 de 3 Acer Iconia B1-A71 LCD Display Replacement: étape 4, image 3 de 3
    • The battery is glued to the LCD display metal shield with a double sided adhesive tape.
    • Use plastic tools and carefully remove it.
    • Remove all tapes from the LCD display metal shield.
  5. Acer Iconia B1-A71 LCD Display Replacement: étape 5, image 1 de 3 Acer Iconia B1-A71 LCD Display Replacement: étape 5, image 2 de 3 Acer Iconia B1-A71 LCD Display Replacement: étape 5, image 3 de 3
    • The LCD display is held by metal frame and some locking clips on it.
    • Use a cutter and a plastic tool to separate the LCD.
    • You have to work slowly so as not to break the display.
    • Now, install the new LCD display and reassemble the tablet.
    • Did you do it successfully?
    • Please SUBSCRIBE to my channel ツ
6 autres ont terminé cette réparation.
ZFix
Membre depuis le 12/09/13
191 308 Réputation
330 tutoriels rédigés
Équipe
Master Techs Membre de l'équipe Master Techs
Community
322 membres
2 535 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 2
30 derniers jours : 5
Total : 11,028
