Aller au contenu principal
Acer Iconia B1-A71 Touch Screen Glass Replacement
Ce dont vous avez besoin
Vidéo d'introduction
  1. Acer Iconia B1-A71 Touch Screen Glass Replacement, Acer Iconia B1-A71   Touch Screen Glass Replacement: étape 1, image 1 de 3 Acer Iconia B1-A71 Touch Screen Glass Replacement, Acer Iconia B1-A71   Touch Screen Glass Replacement: étape 1, image 2 de 3 Acer Iconia B1-A71 Touch Screen Glass Replacement, Acer Iconia B1-A71   Touch Screen Glass Replacement: étape 1, image 3 de 3
    • Because I can't switch-off the tablet, I'm using the reset button to do this.
    • With a cutter and a plastic tool remove the back cover.
    • If you have a memory card inside, don't forget to remove it!
  2. Acer Iconia B1-A71 Touch Screen Glass Replacement: étape 2, image 1 de 2 Acer Iconia B1-A71 Touch Screen Glass Replacement: étape 2, image 2 de 2
    • First, disconnect the battery.
    • Now, disconnect the loudspeaker and remove the back cover.
    • Remove all scotch tapes and disconnect the touch screen flex cable...
    • LCD display flex cable,
    • the microphone,
    • and the WiFi and Bluetooth antennas flex cables.
  3. Acer Iconia B1-A71 Touch Screen Glass Replacement: étape 3, image 1 de 3 Acer Iconia B1-A71 Touch Screen Glass Replacement: étape 3, image 2 de 3 Acer Iconia B1-A71 Touch Screen Glass Replacement: étape 3, image 3 de 3
    • Unscrew 5x screws and rmove the main board.
  4. Acer Iconia B1-A71 Touch Screen Glass Replacement: étape 4, image 1 de 3 Acer Iconia B1-A71 Touch Screen Glass Replacement: étape 4, image 2 de 3 Acer Iconia B1-A71 Touch Screen Glass Replacement: étape 4, image 3 de 3
    • The battery is glued to the LCD display metal shield with a double sided adhesive tape.
    • Use plastic tools and carefully remove it.
    • Remove all tapes from the LCD display metal shield.
  5. Acer Iconia B1-A71 Touch Screen Glass Replacement: étape 5, image 1 de 3 Acer Iconia B1-A71 Touch Screen Glass Replacement: étape 5, image 2 de 3 Acer Iconia B1-A71 Touch Screen Glass Replacement: étape 5, image 3 de 3
    • The LCD display is held by metal frame and some locking clips on it.
    • Use a cutter and a plastic tool to separate the LCD.
    • You have to work slowly so as not to break the display.
    • Now, install the new LCD display and reassemble the tablet.
  6. Acer Iconia B1-A71 Touch Screen Glass Replacement: étape 6, image 1 de 3 Acer Iconia B1-A71 Touch Screen Glass Replacement: étape 6, image 2 de 3 Acer Iconia B1-A71 Touch Screen Glass Replacement: étape 6, image 3 de 3
    • Warm up the touch screen.
    • Start separating from one of the corners. With a cutter, make place for a plastic tool.
    • Keep warm the touchscreen to separate it easily.
    • For us is important to keep only the frame.
  7. Acer Iconia B1-A71 Touch Screen Glass Replacement: étape 7, image 1 de 3 Acer Iconia B1-A71 Touch Screen Glass Replacement: étape 7, image 2 de 3 Acer Iconia B1-A71 Touch Screen Glass Replacement: étape 7, image 3 de 3
    • Use again hot air and a plastic tools to separate the metal screen frame / holder.
  8. Acer Iconia B1-A71 Touch Screen Glass Replacement: étape 8, image 1 de 3 Acer Iconia B1-A71 Touch Screen Glass Replacement: étape 8, image 2 de 3 Acer Iconia B1-A71 Touch Screen Glass Replacement: étape 8, image 3 de 3
    • Before installing the new touch screen, clean the frame and put double side adhesive tape.
    • For the cleaning you can use an alcohol.
  9. Acer Iconia B1-A71 Touch Screen Glass Replacement: étape 9, image 1 de 3 Acer Iconia B1-A71 Touch Screen Glass Replacement: étape 9, image 2 de 3 Acer Iconia B1-A71 Touch Screen Glass Replacement: étape 9, image 3 de 3
    • Again use a double side adhesive tape to install the the metal LCD frame.
  10. Acer Iconia B1-A71 Touch Screen Glass Replacement: étape 10, image 1 de 3 Acer Iconia B1-A71 Touch Screen Glass Replacement: étape 10, image 2 de 3 Acer Iconia B1-A71 Touch Screen Glass Replacement: étape 10, image 3 de 3
6 autres ont terminé cette réparation.
ZFix
Membre depuis le 12/09/13
191 308 Réputation
330 tutoriels rédigés
Équipe
Master Techs Membre de l'équipe Master Techs
Community
322 membres
2 535 tutoriels rédigés
Un commentaire
Hello, i have followed all these instructions but the touch screen desn't work in spite of a reset by the little button and a wipe.
Please, how can i resolve this problem?
houssnijanah - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 2
Total : 25,098
