Introduction
You can find digitizer for about 60 usd / 50 euros on eBay, or from other electronic part sellers...
It is not difficult. There are no resisting connectors. It takes about 2 hours, as removing the glued touchscreen could be quite long...
Start to unclip the back cover inserting a plastic opening tool from microSD connector. Continue to release the back cover uncliping counter-clockwise. Continue to release the back cover uncliping counter-clockwise.
  • Start to unclip the back cover inserting a plastic opening tool from microSD connector.
  • Continue to release the back cover uncliping counter-clockwise.
Ajouter un commentaire
Continue turning around. And that's it !!
  • Continue turning around.
  • And that's it !!
Remove the yellow tape. Unplug both wifi antena connectors. (Green and Black wires)
  • Remove the yellow tape.
  • Unplug both wifi antena connectors. (Green and Black wires)
Remove the single Phillips 000 screw securing the volume buttons circuit board.
  • Remove the single Phillips 000 screw securing the volume buttons circuit board.
Pull the flex cable out the connector. Grab it by the blue plastic strip..
  • Pull the flex cable out the connector.
  • Grab it by the blue plastic strip..
Gently pull up the flex cable to unstick it from the metal plate and from the battery pack. Then remove the volume buttons circuit board. For the A3-A11 (3G) model, the cellular board is placed just over the flex cable, where sticked to the metal plate. (you can see the empty spot for the connector on the logic board)
  • Gently pull up the flex cable to unstick it from the metal plate and from the battery pack.
  • Then remove the volume buttons circuit board.
  • For the A3-A11 (3G) model, the cellular board is placed just over the flex cable, where sticked to the metal plate. (you can see the empty spot for the connector on the logic board)
Pry up the white bars to unlock the two connectors. Pry up the white bars to unlock the two connectors.
  • Pry up the white bars to unlock the two connectors.
Remove the flex cable pulling it out its two connectors. Remove the flex cable pulling it out its two connectors.
  • Remove the flex cable pulling it out its two connectors.
Pry up the black bar to unlock the camera connector Gently pull away the camera out the connector. Gently pull away the camera out the connector.
  • Pry up the black bar to unlock the camera connector
  • Gently pull away the camera out the connector.
Unplug both connectors just pulling them out.
  • Unplug both connectors just pulling them out.
Unlock both touchscreen connectors pulling up grey bars. Pull out the two flex cables.
  • Unlock both touchscreen connectors pulling up grey bars.
  • Pull out the two flex cables.
Peel off the cristal tape pieces upon each connector side. Peel off the cristal tape pieces upon each connector side. Peel off the cristal tape pieces upon each connector side.
  • Peel off the cristal tape pieces upon each connector side.
You can : Pull out grabbing the cable connector by black taped part. Push the cable connector with a spudger, at both of its extremity. Or with a large flat one on the gold part.
  • You can :
    • Pull out grabbing the cable connector by black taped part.
    • Push the cable connector with a spudger, at both of its extremity. Or with a large flat one on the gold part.
    • Both ways silultaneously...
  • Be careful !!
  • Remove the display cable.
Pry up the vibrator to release it.
  • Pry up the vibrator to release it.
Remove the four Phillips screws securing the two speakers.
  • Remove the four Phillips screws securing the two speakers.
Peel off the two tape pieces securing the cable  linking speakers.
  • Peel off the two tape pieces securing the cable linking speakers.
  • Remove speakers and cable.
Remove the four Phillips screws securing the motherboard.
  • Remove the four Phillips screws securing the motherboard.
Disconnect the front facing camera with a spudger. Introduce a flat spudger between the motherboard and the camera flex cable.
  • Disconnect the front facing camera with a spudger.
  • Introduce a flat spudger between the motherboard and the camera flex cable.
  • Then, rotate the spudger 90°.
  • It should separate easily !
  • Do not use excessive force. If it does not work, you probably are not correctly placed.
Peel off coper tapes from the metal plate. Do not use excessive force to peel coper tapes off the metal plate. Doing so may tear the coper.
  • Peel off coper tapes from the metal plate.
  • Do not use excessive force to peel coper tapes off the metal plate. Doing so may tear the coper.
Peel off the aluminium tape making ground contact. Do not use excessive force to peel the  aluminium tape off the metal plate. Doing so may tear the aluminium.
  • Peel off the aluminium tape making ground contact.
  • Do not use excessive force to peel the aluminium tape off the metal plate. Doing so may tear the aluminium.
Remove two remaining Phillips screws securing the metal plate.
  • Remove two remaining Phillips screws securing the metal plate.
Release the touchscreen circuit board from the adhesive securing it to the display below. Introduce a spudger and unstick the back of the circuit.
  • Release the touchscreen circuit board from the adhesive securing it to the display below.
  • Introduce a spudger and unstick the back of the circuit.
  • There are no components protruding from the underside of the board !
3 points to remove the metal plate with the battery pack :
  • 3 points to remove the metal plate with the battery pack :
    • Yellow arrows : only two small clip still retain the metal plate (all screws were removed during previous steps).
    • Blue arrows : lift up the metal plate until pins are released (blue circles).
    • Orange arrows : pull towards you the metal plate to release the plate from top cleats.
Lift off the display to remove it. There are eight rubber pads which hold gently the display to the plastic frame.
  • Lift off the display to remove it.
  • There are eight rubber pads which hold gently the display to the plastic frame.
Here starts the painfull work. The touchscreen is strongly sticked to the frame with a foamed double-sided tape. You can heat up the taped area with an hairdryer to decrease to tape resistance.
  • Here starts the painfull work.
  • The touchscreen is strongly sticked to the frame with a foamed double-sided tape.
  • You can heat up the taped area with an hairdryer to decrease to tape resistance.
  • When soften, introduce plastic opening tools to separate frame and touchscreen.
  • Be careful as the touchscreen will broke easily in little pieces when prying up.
Introduce plastic opening tools, turning around to separate frame and touchscreen. Be careful as the touchscreen will broke easily in little pieces. Be careful as the touchscreen will broke easily in little pieces.
  • Introduce plastic opening tools, turning around to separate frame and touchscreen.
  • Be careful as the touchscreen will broke easily in little pieces.
As the touchscreen will probably be broken in a lot of pieces, put cristal tape on remaining touchscreen fragments. It will prevent breaking in multiple tiny bursts. And protect your eyes ! It will prevent breaking in multiple tiny bursts. And protect your eyes !
  • As the touchscreen will probably be broken in a lot of pieces, put cristal tape on remaining touchscreen fragments.
  • It will prevent breaking in multiple tiny bursts. And protect your eyes !
Remove all remaining tape marks before applying new tape. I used standard foamed double-sided tape. Cut to the right size so there are no remainming free space, which would allow dirt to squeeze through !
  • Remove all remaining tape marks before applying new tape.
  • I used standard foamed double-sided tape.
  • Cut to the right size so there are no remainming free space, which would allow dirt to squeeze through !
  • Peel off the interior protective plastic film from the new touchscreen.
  • Place it into the main frame.
  • Press firmly to the adhesive to tighten it!
7 autre(s) ont terminé cette réparation.
Cecil His Mahier
Membre depuis le 21/11/2014
231 Réputation
1 tutoriel rédigé
Excellent, just waiting for my battery to charge up so I can test it.
Rick Lecompte - Réponse
Too complicated for me, one cable broken. Better to order glass after successful dissassembly
Eckart Wittlinger - Réponse
You saved my day! It was the first time for me to repair the touchscreen of a tablet and everything works fine.
Additionally I have some remarks:
1) The named tools are useful and were needed. For the single steps it is therefore necessary to order a set of tools including the double-sided tape.
2) I repaired an A3-A11 and obviously there a some differences regarding the structure: There are two more cooper plates like screenshots 19 and 20 solid at the battery plate and two more connectors like wifi antenna.
This was not a problem because the cooper plates were stucked at the frame with a plastic peace and could be easily solved. The connectors could be also solved easily.
3) The reversed action of step 23 (assembly of metal plate) is tricky and must be done very carefully. Otherwise it could be that the back cover doesn't fit correctly.
4) The usage of a hair dryer for the removal of tape should be done carefully otherwise the frame could be warped (step 26).
sgerdt - Réponse
Perfekte Anleitung! Vielen Dank!
Kleine - hoffentlich hilfreiche - Anmerkungen:
a) Als "plastic opening tools" habe ich Gitarren-Plektren in 1mm Stärke verwendet.
b) Das kaputte Display habe ich außen vollflächig komplett mit Paketband abgeklebt, das verhindert das Herumfliegen kleiner Glassplitter.
c) Vom Verwenden eines Föhnes würde ich ganz abraten, da sich der Rahmen sonst leicht verzieht.
Man muß halt Geduld beim Lösen des Glases aus dem Rahmen haben.
d) Die Dauer der Reparatur würde ich eher mit 3 Stunden ansetzen.
nethippo - Réponse
worked great…thanks a bunch! Getting all the old tape off took the longest. The other things took less than 10 minutes. I used double sided 3M molding tape. it worked but was a little thicker than the original tape. It’s strong though. I’ve had issues in other tape not holding if the plastic was warped a bit during the heat process. Thanks again…
Marty Collins - Réponse
Voir les statistiques:
Dernières 24 heures : 6
7 derniers jours : 41
30 derniers jours : 199
Total : 19,458
