Introduction
If you forgot your password, PIN, pattern drill, or if you have problem with your Android OS, you can make a Factory / Hard reset.
Please SUBSCRIBE to my channel ツ
Vidéo d'introduction
Power off the tablet. Press and hold the Volume Up and the Power button. After 3 seconds release the Power On button but continue holding the Volume Up button. In  the Select Boot Mode use the Volume Up/Down keys to navigate and the Power button to select the desired option. [SD Image Update Mode]
  • Power off the tablet. Press and hold the Volume Up and the Power button. After 3 seconds release the Power On button but continue holding the Volume Up button. In the Select Boot Mode use the Volume Up/Down keys to navigate and the Power button to select the desired option.
  • [SD Image Update Mode]
  • wipe data/factory reset
  • Yes - delete all user data
  • Reboot system now.
  • Your tablet will reboot and go to the Welcome screen.
when i reboot it it has an red traingle
Khia Ragin - Réponse
Hahaha thanks it worked for me im so grateful
Jennifer Hill - Réponse
My tab cannot ON....what happen, what should I do?
Zamri - Réponse
Awesome thanks a lot it worked on my tablet
alina - Réponse
it will not working even i try bypass way give me some another trick
Kings Order - Réponse
on my tablet I did what you said but all I got was in tiny letters bottom left was =FASTBOOT mode… any suggestions but this is a acer iconica one 10
norma goddard - Réponse
acer iconica one 10 it will not do any other suggestions all I got was in tiny print bottom left corner was = fastboot mode
Mine just stays in the welcome screen…any ideas?
recroom55 - Réponse
After hitting reboot the tablet just stays on the welcome screen…thoughts?
recroom55 - Réponse
did not work saids acer that it
ken - Réponse
23 autre(s) ont terminé cette réparation.
ZFix
Membre depuis le 09/12/2013
150 379 Réputation
424 tutoriels rédigés
Équipe
Master Techs Membre de l'équipe Master Techs
Community
274 membres
713 tutoriels rédigés
14 commentaires
This is not workin it keep saying enter the email .... n when dun its still not going in
Janiah Boucher - Réponse
I did this and the tablet is stuck at the logo !
pussycatdevika - Réponse
I have done this. But I'm stuck at email address I use when i first bought. I don't remember my email address. What can I do
Sameena - Réponse
Yep I am having the same problem and have done all kinds of searching on how to override it or some other fix...
Kim Haynes -
Stuck on email address. Can't remember email address I used
Sameena - Réponse
Does not work... Acer does not have a solution.... but money of course !
JR Lamarche - Réponse
It stuck on welcome page and I can topen it
sammiewalker1588 - Réponse
My Acer lconia tablet was reset. What I can do
Faraz Gohar - Réponse
Did this process with a few tweaks…and it hung on the Acer logo, so I powered off and back on and began the start up process. Great advice and it worked perfectly!
Crystal W. Bishop - Réponse
I have problem with my tablet acer B1-770
i forgot pattern password
plz help me
thanks
Waseem - Réponse
I am stuck on the icon with tje red triangle with a ! In it. Pls help
Missy Simmons - Réponse
It went to the welcome screen but it wants me to enter numbers to unlock. I dont know what numbers it was set up with.
What if you only get => FASTBOOT mode… when you press the volume + and power button. Any ideas what to do then?
Jennifer - Réponse
Use the power and the volume DOWN button. The volume up button only shows your fast boot
Dan - Réponse
Ajouter un commentaire
Voir les statistiques:
Dernières 24 heures : 80
7 derniers jours : 522
30 derniers jours : 2,353
Total : 57,599
