Aller au contenu principal
Aether Cone Speaker Disassembly
Ce dont vous avez besoin
  1. Aether Cone Speaker Disassembly, Remove the Rubber Foot: étape 1, image 1 de 3 Aether Cone Speaker Disassembly, Remove the Rubber Foot: étape 1, image 2 de 3 Aether Cone Speaker Disassembly, Remove the Rubber Foot: étape 1, image 3 de 3
    • It is held on with some double sided adhesive tape, just peel it back carefully from a corner
    • Then remove all the screws shown in the picture
  2. Aether Cone Speaker Disassembly, Remove frame screws and PCB: étape 2, image 1 de 3 Aether Cone Speaker Disassembly, Remove frame screws and PCB: étape 2, image 2 de 3 Aether Cone Speaker Disassembly, Remove frame screws and PCB: étape 2, image 3 de 3
    • Next remove the small circuit board on the end of the silver ribbon cable, it is held on with some more double sided adhesive
    • Then remove the two allen head bolts hidden inside the case that hold the outer casing to the mid frame.
  3. Aether Cone Speaker Disassembly, remove case form midframe: étape 3, image 1 de 3 Aether Cone Speaker Disassembly, remove case form midframe: étape 3, image 2 de 3 Aether Cone Speaker Disassembly, remove case form midframe: étape 3, image 3 de 3
    • Remove the ribbon cable and the connector holding the case to the mid frame
  4. Aether Cone Speaker Disassembly, remove battery support screws: étape 4, image 1 de 3 Aether Cone Speaker Disassembly, remove battery support screws: étape 4, image 2 de 3 Aether Cone Speaker Disassembly, remove battery support screws: étape 4, image 3 de 3
    • undo the screws that hold the metal bracket in place and then disconnect the battery.
    • The battery can then be gently pulled off the mid frame as it is held on by double sided adhesive foam tape.
    • The battery is a 7.2v 5200mah battery consisting of 4 18650 cells.
  5. Aether Cone Speaker Disassembly, Disconnect cables: étape 5, image 1 de 2 Aether Cone Speaker Disassembly, Disconnect cables: étape 5, image 2 de 2
    • Remove the connectors plugged into the main circuit board
  6. Aether Cone Speaker Disassembly, Remove PCB: étape 6, image 1 de 3 Aether Cone Speaker Disassembly, Remove PCB: étape 6, image 2 de 3 Aether Cone Speaker Disassembly, Remove PCB: étape 6, image 3 de 3
    • remove the screws and the main circuit board can be taken off the mid frame.
    • Hopefully the photos can help with identifying the chips
  7. Aether Cone Speaker Disassembly, Remove mid frame screws: étape 7, image 1 de 2 Aether Cone Speaker Disassembly, Remove mid frame screws: étape 7, image 2 de 2
    • remove all the long screws around the mid frame
    • The midframe can then be lifted off
  8. Aether Cone Speaker Disassembly, Remove the mid frame: étape 8, image 1 de 2 Aether Cone Speaker Disassembly, Remove the mid frame: étape 8, image 2 de 2
    • this then reveals the two tweeters and the 3 inch driver which provides the excellent sound quality.
6 autres ont terminé cette réparation.
Nick Charlton
Membre depuis le 01/05/18
337 Réputation
1 tutoriel rédigé
9 commentaires
it would be great to get access to the firmware to enable the microphone and make it work as an assistant via Google API or Alexa API
peteandmika - Réponse
Anyway of adding a 3.5mm line in socket to connect an Amazon Alexa to it ?
s_bell1 - Réponse
I also want to know if this is possible.
I’ve got four of these around the house but connected via bluetooth (which is pretty unstable) they are not in sync.
Would be great to be able to plug directly into an amazon dot?
Any suggestions for a work around would be great?
alainsworth -
Mine has stopped charging so is only usable plugged in. Is this a common problem can it be fixed easily? I checked various voltages on the battery board but cant find any reference to what they should be.
Russ - Réponse
Mine stopped charging too. I just changed all the batteries and it all works fine again now.
Glen Shepherd -
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 5
30 derniers jours : 28
Total : 1,615
