Aller au contenu principal
Afridev Pump Rod Replacement
Ce dont vous avez besoin
  1. Afridev Pump Rod Replacement, Head: étape 1, image 1 de 2 Afridev Pump Rod Replacement, Head: étape 1, image 2 de 2
    • Assemble the required tools, including the Afridev tool and crescent wrenches.
  2. Afridev Pump Rod Replacement: étape 2, image 1 de 3 Afridev Pump Rod Replacement: étape 2, image 2 de 3 Afridev Pump Rod Replacement: étape 2, image 3 de 3
    • Perform a water test on the pump, by raising and lowering the handle a full 40 strokes. A properly performing pump will yield greater than 10 liters.
  3. Afridev Pump Rod Replacement: étape 3, image 1 de 2 Afridev Pump Rod Replacement: étape 3, image 2 de 2
    • Loosen the bolt on front of the face plate with the Afridev tool.
    • Remove the plate from the pump by lifting it straight up.
  4. Afridev Pump Rod Replacement, Axle and Handle: étape 4, image 1 de 3 Afridev Pump Rod Replacement, Axle and Handle: étape 4, image 2 de 3 Afridev Pump Rod Replacement, Axle and Handle: étape 4, image 3 de 3
    • Insert the T-handle into the top cylinder of the exposed pump rod.
  5. Afridev Pump Rod Replacement: étape 5, image 1 de 2 Afridev Pump Rod Replacement: étape 5, image 2 de 2
    • Loosen the 2 bolts on either side of handle.
    • It is not necessary to remove the bolt at this time; however, take caution to not let the bolt fall out of the handle.
  6. Afridev Pump Rod Replacement: étape 6, image 1 de 3 Afridev Pump Rod Replacement: étape 6, image 2 de 3 Afridev Pump Rod Replacement: étape 6, image 3 de 3
    • Loosen the 2 bolts on either side of the head to remove the handle from the pump rod.
  7. Afridev Pump Rod Replacement: étape 7, image 1 de 2 Afridev Pump Rod Replacement: étape 7, image 2 de 2
    • Lift the handle to a horizontal position.
  8. Afridev Pump Rod Replacement: étape 8, image 1 de 3 Afridev Pump Rod Replacement: étape 8, image 2 de 3 Afridev Pump Rod Replacement: étape 8, image 3 de 3
    • While one person lifts up on the T-handle, remove the bolt and connection pieces.
  9. Afridev Pump Rod Replacement: étape 9, image 1 de 3 Afridev Pump Rod Replacement: étape 9, image 2 de 3 Afridev Pump Rod Replacement: étape 9, image 3 de 3
    • Remove the bolt and connection pieces from the handle.
    • Set the bolt pieces in a sanitary place, such as a bucket, to prevent contamination.
  10. Afridev Pump Rod Replacement: étape 10, image 1 de 2 Afridev Pump Rod Replacement: étape 10, image 2 de 2
    • Remove the handle from the pump.
    • Be sure to set the handle in a sanitary place to prevent contamination.
  11. Afridev Pump Rod Replacement, Pump Rod: étape 11, image 1 de 2 Afridev Pump Rod Replacement, Pump Rod: étape 11, image 2 de 2
    • Grab firmly on the T-handle and lift the pump rod straight up.
    • Expose the first connection of the pump rod, and support the portion below the connection.
  12. Afridev Pump Rod Replacement: étape 12, image 1 de 2 Afridev Pump Rod Replacement: étape 12, image 2 de 2
    • While holding the pump rod below the first connection tightly, lower the first portion of the rod to a horizontal position.
  13. Afridev Pump Rod Replacement: étape 13, image 1 de 3 Afridev Pump Rod Replacement: étape 13, image 2 de 3 Afridev Pump Rod Replacement: étape 13, image 3 de 3
    • Unhook the first connection by pushing it out and down, then pulling it away from the rest of the rod.
  14. Afridev Pump Rod Replacement: étape 14, image 1 de 3 Afridev Pump Rod Replacement: étape 14, image 2 de 3 Afridev Pump Rod Replacement: étape 14, image 3 de 3
    • Repeat steps 11-13 for the remaining sections of pump rod.
    • Be sure to set the pump rod segments above the ground to avoid contamination.
Jake Devincenzi
Membre depuis le 04/18/11
117 328 Réputation
57 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 6
30 derniers jours : 17
Total : 369
