Introduction
The lens protector is a plastic cover that protects the lens from scratches, dirt and other debris. Use this guide to replace the lens protector.
Locate the battery compartment on the back of the camera. It is the panel with the plastic ridges for simple removal.
  • Locate the battery compartment on the back of the camera. It is the panel with the plastic ridges for simple removal.
  • Slide the battery compartment cover down off of the camera body.
Ajouter un commentaire
Pry up the battery from the bottom using a finger and remove the batter from the case.
  • Pry up the battery from the bottom using a finger and remove the batter from the case.
Remove the lanyard by pulling the grey lace through the black string loop.
  • Remove the lanyard by pulling the grey lace through the black string loop.
  • Pull black string loop through the silver bracket.
Use a plastic opening tool to pry off the black control cover.
  • Use a plastic opening tool to pry off the black control cover.
  • The face plates are glued, so use force to pry the face plates from the camera body.
Use a plastic opening tool to pry off the ridged back face plate and the black button.
  • Use a plastic opening tool to pry off the ridged back face plate and the black button.
  • The button is loose and should come off with little or no effort.
Use a plastic opening tool to pry off the silver face plate.
  • Use a plastic opening tool to pry off the silver face plate.
Open the USB cover to expose the small machine screw. Use the Phillips #00 screwdriver to unscrew the six 0.5cm machine case screws (distributed around the camera body). These small screws are easy to lose. Place the removed screws in an organized container to avoid losing them.
  • Open the USB cover to expose the small machine screw.
  • Use the Phillips #00 screwdriver to unscrew the six 0.5cm machine case screws (distributed around the camera body).
  • These small screws are easy to lose. Place the removed screws in an organized container to avoid losing them.
Pull off the side control panel.
  • Pull off the side control panel.
Flip open the screen by pulling the loose end of the screen away from the case. Use tweezers to remove the two outside rubber dots to reveal the two 0.5cm machine screws.
  • Flip open the screen by pulling the loose end of the screen away from the case.
  • Use tweezers to remove the two outside rubber dots to reveal the two 0.5cm machine screws.
  • Use the #00 Phillips Screwdriver to remove both screws.
Pull the body apart from the bottom of device just enough to make space to remove the silver plastic strap holder. Use tweezers to remove the silver plastic strap holder.
  • Pull the body apart from the bottom of device just enough to make space to remove the silver plastic strap holder.
  • Use tweezers to remove the silver plastic strap holder.
  • Use a plastic opening tool to pry off the lens protector.
Zachary Yun
Membre depuis le 03/04/2012
7 Réputation
5 tutoriels rédigés
Équipe
Cal Poly, Team 5-5, Forte Spring 2012 Membre de l'équipe Cal Poly, Team 5-5, Forte Spring 2012
CPSU-FORTE-S12S5G5
5 membres
5 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 1
Total : 463
