Introduction
The reload slider spring brings the reload slider back to the front once the blaster is ready to fire.
Pièces
Aucune pièce nécessaire.
Using a screwdriver, remove the two 11.6 mm phillips 00 screws holding the grey slider together. Remove grey slider from the main body of the blaster. Remove grey slider from the main body of the blaster.
  • Using a screwdriver, remove the two 11.6 mm phillips 00 screws holding the grey slider together.
  • Remove grey slider from the main body of the blaster.
Ajouter un commentaire
Using a screwdriver, remove the six 9 mm phillips 00 screws holding the main body together. Using a screwdriver, remove the six 9 mm phillips 00 screws holding the main body together. Using a screwdriver, remove the six 9 mm phillips 00 screws holding the main body together.
  • Using a screwdriver, remove the six 9 mm phillips 00 screws holding the main body together.
Using the plastic opening tools, carefully take apart the main case of the blaster to leave the inside exposed. Using the plastic opening tools, carefully take apart the main case of the blaster to leave the inside exposed. Using the plastic opening tools, carefully take apart the main case of the blaster to leave the inside exposed.
  • Using the plastic opening tools, carefully take apart the main case of the blaster to leave the inside exposed.
Carefully grab the metal pin keeping the air system and top spring, and slide it outwards. This will release the air system with the plunger completely. Carefully grab the metal pin keeping the air system and top spring, and slide it outwards. This will release the air system with the plunger completely. Carefully grab the metal pin keeping the air system and top spring, and slide it outwards. This will release the air system with the plunger completely.
  • Carefully grab the metal pin keeping the air system and top spring, and slide it outwards. This will release the air system with the plunger completely.
Using a screwdriver, remove the 7.5 mm phillips 00 screw holding the top spring to the reload slider. Using a screwdriver, remove the 7.5 mm phillips 00 screw holding the top spring to the reload slider.
  • Using a screwdriver, remove the 7.5 mm phillips 00 screw holding the top spring to the reload slider.
Alfredo Antolinez
Membre depuis le 22/09/2014
301 Réputation
3 tutoriels rédigés
Équipe
USF Tampa, Team 3-1, Brown Fall 2014 Membre de l'équipe USF Tampa, Team 3-1, Brown Fall 2014
USFT-BROWN-F14S3G1
3 membres
5 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 1
Total : 138
