Introduction
In the case that your Alcatel One Touch Pop 7 Tablet is not registering sound when recording, their may be a problem with the microphone. This guide will show you how to replace the microphone within this device.
Begin by opening SD port cover as this is the best location to start prying.
  • Begin by opening SD port cover as this is the best location to start prying.
Ajouter un commentaire
Use the plastic opening tool to pry around the edges of the back cover until it pops off.
  • Use the plastic opening tool to pry around the edges of the back cover until it pops off.
Kits de RAM Mac
Accélérez votre Mac. Maximisez sa mémoire.
Kits de RAM Mac
Obtenez plus de mémoire sur votre Mac.
Disconnect battery by pulling up on the ZIF connector with precision tweezers for safety.
  • Disconnect battery by pulling up on the ZIF connector with precision tweezers for safety.
Remove the Microphone from it's slot with the precision tweezers.
  • Remove the Microphone from it's slot with the precision tweezers.
Solder the wires off of the motherboard with a soldering iron while holding the wires with the precision tweezers.  For information on how to solder safely and correctly go to this link: Comment souder et dessouder des connexions
  • Solder the wires off of the motherboard with a soldering iron while holding the wires with the precision tweezers. For information on how to solder safely and correctly go to this link: Comment souder et dessouder des connexions
Philip Schenck
Membre depuis le 20/03/2018
181 Réputation
2 tutoriels rédigés
Équipe
IUPUI, Team S6-G2, Baechle Spring 2018 Membre de l'équipe IUPUI, Team S6-G2, Baechle Spring 2018
IUPUI-BAECHLE-S18S6G2
3 membres
4 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 1
7 derniers jours : 2
30 derniers jours : 11
Total : 22
