Introduction
In this guide, we will be showing you how to remove and replace the Base Panel.
Pièces
Aucune pièce nécessaire.
Ajouter un commentaire
Close the display and turn the computer over.
  • Close the display and turn the computer over.
  • Make sure PC is turned off!
Loosen the captive screws that secure the base panel to the computer base.
  • Loosen the captive screws that secure the base panel to the computer base.
Using a plastic scribe, gently release the tabs that secure the base panel to the computer base.
  • Using a plastic scribe, gently release the tabs that secure the base panel to the computer base.
Kits RAM pour Mac
Accélérez votre Mac. Maximisez sa mémoire.
Kits RAM pour Mac
Augmentez la mémoire de votre Mac.
Slide and remove the base panel from the computer base.
  • Slide and remove the base panel from the computer base.
Disconnect the Battery cable from the system board.
  • Disconnect the Battery cable from the system board.
  • Turn the computer over.
  • Press and hold power button for 5 seconds to ground the system board.
Connect the battery cable to the system board.
  • Connect the battery cable to the system board.
Tighten the captive screws that secure the base panel to the computer base.
  • Tighten the captive screws that secure the base panel to the computer base.
Teren Wallace
Membre depuis le 18/12/2017
40 107 Réputation
370 tutoriels rédigés
Équipe
Informative Technologies Inc. Membre de l'équipe Informative Technologies Inc.
Community
15 membres
846 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 3
30 derniers jours : 19
Total : 80
