Aller au contenu principal
Alienware 17 R2 Base Panel Replacement
Ce dont vous avez besoin
  1. Alienware 17 R2 Base Panel Replacement, Close the Display: étape 2, image 1 de 1
    • Close the display and turn the computer over.
    • Make sure PC is turned off!
  2. Alienware 17 R2 Base Panel Replacement, Loosen Screws: étape 3, image 1 de 1
    • Loosen the captive screws that secure the base panel to the computer base.
  3. Alienware 17 R2 Base Panel Replacement, Releasing Tabs: étape 4, image 1 de 1
    • Using a plastic scribe, gently release the tabs that secure the base panel to the computer base.
  4. Alienware 17 R2 Base Panel Replacement, Remove Base Panel: étape 5, image 1 de 1
    • Slide and remove the base panel from the computer base.
  5. Alienware 17 R2 Base Panel Replacement, Disconnect Battery Cable: étape 6, image 1 de 1
    • Disconnect the Battery cable from the system board.
    • Turn the computer over.
    • Press and hold power button for 5 seconds to ground the system board.
  6. Alienware 17 R2 Base Panel Replacement, Battery Cable: étape 9, image 1 de 1
    • Connect the battery cable to the system board.
  7. Alienware 17 R2 Base Panel Replacement, Tighten Screws: étape 10, image 1 de 1
    • Tighten the captive screws that secure the base panel to the computer base.
Terrence15
Membre depuis le 12/18/17
79 121 Réputation
441 tutoriels rédigés
Équipe
RampUP America, Inc. Membre de l'équipe RampUP America, Inc.
Community
42 membres
1 985 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 6
Total : 765
