Aller au contenu principal
Alienware 17 R2 Memory Modules Replacement
Ce dont vous avez besoin
  1. Alienware 17 R2 Memory Modules Replacement, Popping up Memory Module: étape 1, image 1 de 1
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer and follow the steps in Before Working Inside Your Computer. After working inside your computer, follow the instructions in After Working Inside Your Computer.
    • Remove the base panel.
    • Using your fingertips, carefully spread apart the securing clips on each end of the memory-module slot until the memory module pops up.
  2. Alienware 17 R2 Memory Modules Replacement, Remove Memory Module: étape 2, image 1 de 2 Alienware 17 R2 Memory Modules Replacement, Remove Memory Module: étape 2, image 2 de 2
    • Slide and remove the memory module from the memory-module slot.
  3. Alienware 17 R2 Memory Modules Replacement, Aligining the Notch: étape 3, image 1 de 1
    • Align the notch on the new memory module with the tab on the memory- module slot.
  4. Alienware 17 R2 Memory Modules Replacement, Installing Memory Module: étape 4, image 1 de 2 Alienware 17 R2 Memory Modules Replacement, Installing Memory Module: étape 4, image 2 de 2
    • Slide the memory module firmly into the slot at an angle and press the memory module down until it clicks into place.
    • If you do not hear the click, remove the memory module and reinstall it.
Terrence15
Membre depuis le 12/18/17
79 121 Réputation
441 tutoriels rédigés
Équipe
RampUP America, Inc. Membre de l'équipe RampUP America, Inc.
Community
42 membres
1 985 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 1
Total : 452
