Aller au contenu principal
Alienware 17 R2 Power-Button Board Replacement
Ce dont vous avez besoin
  1. Alienware 17 R2 Power-Button Board Replacement, Removing the Base Panel: étape 1, image 1 de 3 Alienware 17 R2 Power-Button Board Replacement, Removing the Base Panel: étape 1, image 2 de 3 Alienware 17 R2 Power-Button Board Replacement, Removing the Base Panel: étape 1, image 3 de 3
    • WARNING : Before working inside your computer, read the safety information that shipped with your computer and follow the steps in Before Working Inside Your Computer. After working inside your computer, follow the instructions in After Working Inside Your Computer.
    • Make sure the base panel is removed.
    • Make sure the palm rest is removed too.
    • Lift the latches and disconnect the touch-pad cable and the status-light cable from the power-button board.
  2. Alienware 17 R2 Power-Button Board Replacement, Disconnecting the Power-Board Cable: étape 2, image 1 de 2 Alienware 17 R2 Power-Button Board Replacement, Disconnecting the Power-Board Cable: étape 2, image 2 de 2
    • Disconnect the power-button cable from the power-button board.
    • Remove the screws that secure the power-button board to the palm-rest assembly.
    • Lift the power-button board off the palm-rest assembly.
    • Align the screw holes on the power-button board with the screw holes on the palm-rest assembly.
    • Replace the screws that secure the power-button board to the palm-rest assembly.
    • Connect the power-button board cable to the power-button board.
    • Slide the touch-pad cable and the status-light cable into their respective connectors on the power-button board and press down the latches to secure the cables.
Terrence15
Membre depuis le 12/18/17
79 091 Réputation
441 tutoriels rédigés
Équipe
RampUP America, Inc. Membre de l'équipe RampUP America, Inc.
Community
42 membres
1 985 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 4
Total : 462
