Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Alienware 17 R4 Battery Replacement
Ce dont vous avez besoin
  1. Alienware 17 R4 Battery Replacement, Base Cover: étape 1, image 1 de 1
    • Use a PH1 screwdriver bit to remove the six M2.5x13 screws (2.4 mm) on the back of the laptop.
    • Use a PH1 screwdriver bit to loosen the one M2x3 screw (1.9 mm).
    • The M2x3 screw (1.9 mm) does not come out completely.
    Demander à FixBot
    Ajouter un commentaire
  2. Alienware 17 R4 Battery Replacement: étape 2, image 1 de 2 Alienware 17 R4 Battery Replacement: étape 2, image 2 de 2
    • Pull the base cover up to remove it.
    • If you are having trouble, insert a plastic opening tool into the divots along the laptop's edges to loosen.
    • Removing the cover may require some force.
    Demander à FixBot
  3. Alienware 17 R4 Battery Replacement, Hard Disk Drive (HDD): étape 3, image 1 de 3 Alienware 17 R4 Battery Replacement, Hard Disk Drive (HDD): étape 3, image 2 de 3 Alienware 17 R4 Battery Replacement, Hard Disk Drive (HDD): étape 3, image 3 de 3
    • Disconnect the battery connector cable, located on the right side of the laptop, above the hard disk drive.
    • Once you have removed the cable, wait 5-10 minutes to allow the laptop to power down.
    • Failure to remove the battery connector cable properly may damage other parts of the laptop.
    Demander à FixBot
  4. Alienware 17 R4 Battery Replacement: étape 4, image 1 de 3 Alienware 17 R4 Battery Replacement: étape 4, image 2 de 3 Alienware 17 R4 Battery Replacement: étape 4, image 3 de 3
    • Use a PH1 screwdriver bit to remove the four M2.5x5 screws (2.4 mm) on the hard disk drive.
    Demander à FixBot
  5. Alienware 17 R4 Battery Replacement: étape 5, image 1 de 3 Alienware 17 R4 Battery Replacement: étape 5, image 2 de 3 Alienware 17 R4 Battery Replacement: étape 5, image 3 de 3
    • Gently lift the HDD cable to disconnect it from the laptop.
    Demander à FixBot
  6. Alienware 17 R4 Battery Replacement: étape 6, image 1 de 2 Alienware 17 R4 Battery Replacement: étape 6, image 2 de 2
    • Pull the hard drive up to remove.
    Demander à FixBot
  7. Alienware 17 R4 Battery Replacement, RAM: étape 7, image 1 de 3 Alienware 17 R4 Battery Replacement, RAM: étape 7, image 2 de 3 Alienware 17 R4 Battery Replacement, RAM: étape 7, image 3 de 3
    • Move the metal sidings outward to release the RAM card.
    Demander à FixBot
  8. Alienware 17 R4 Battery Replacement: étape 8, image 1 de 1
    • Slide the RAM card out towards yourself to remove it.
    • Repeat the same step for the RAM card above.
    • Slide the RAM card out carefully to avoid damaging it.
    Demander à FixBot
  9. Alienware 17 R4 Battery Replacement, Wi-Fi card: étape 9, image 1 de 1
    • Locate the WI-FI card.
    Demander à FixBot
  10. Alienware 17 R4 Battery Replacement: étape 10, image 1 de 2 Alienware 17 R4 Battery Replacement: étape 10, image 2 de 2
    • Peel back plastic cover of wi-fi card.
    • Use a PH1 screwdriver bit and remove the one M2x3 screw (1.9 mm)
    Demander à FixBot
  11. Alienware 17 R4 Battery Replacement: étape 11, image 1 de 3 Alienware 17 R4 Battery Replacement: étape 11, image 2 de 3 Alienware 17 R4 Battery Replacement: étape 11, image 3 de 3
    • Gently undo the clips attached to the wi-fi card.
    • If the clip is not gently removed it is possible that the entire base will be torn off the wi-fi card. You will need to purchase a new wi-fi card if this occurs.
    Demander à FixBot
  12. Alienware 17 R4 Battery Replacement: étape 12, image 1 de 2 Alienware 17 R4 Battery Replacement: étape 12, image 2 de 2
    • Locate the cables that connect the wi-fi card.
    • Gently pull upwards to remove cables and slide the wi-fi card out from its slot.
    Demander à FixBot
  13. Alienware 17 R4 Battery Replacement, Solid State Drive: étape 13, image 1 de 2 Alienware 17 R4 Battery Replacement, Solid State Drive: étape 13, image 2 de 2
    • Remove the one M2x3 screw (1.9 mm) using a PH1 screwdriver bit
    Demander à FixBot
  14. Alienware 17 R4 Battery Replacement: étape 14, image 1 de 2 Alienware 17 R4 Battery Replacement: étape 14, image 2 de 2
    • Slide the solid state drive towards yourself to prevent damage to the card.
    Demander à FixBot
  15. Alienware 17 R4 Battery Replacement, Fan Shroud: étape 15, image 1 de 3 Alienware 17 R4 Battery Replacement, Fan Shroud: étape 15, image 2 de 3 Alienware 17 R4 Battery Replacement, Fan Shroud: étape 15, image 3 de 3
    • Remove the two M2.5x7 screws (2.44 mm) located on the rear panel using a PH1 screwdriver bit.
    Demander à FixBot
  16. Alienware 17 R4 Battery Replacement: étape 16, image 1 de 2 Alienware 17 R4 Battery Replacement: étape 16, image 2 de 2
    • Insert the plastic opening tool under the fan shroud to slowly lift it up.
    • Repeat process on the middle and opposite side.
    Demander à FixBot
  17. Alienware 17 R4 Battery Replacement: étape 17, image 1 de 2 Alienware 17 R4 Battery Replacement: étape 17, image 2 de 2
    • Firmly lift the plastic opening tool and pull the fan shroud towards you.
    • This will take a large amount of force and will not come out easily the first time.
    • Careful not to tear out the piece causing damage to the fan shroud
    Demander à FixBot
  18. Alienware 17 R4 Battery Replacement, Plastic Cover: étape 18, image 1 de 3 Alienware 17 R4 Battery Replacement, Plastic Cover: étape 18, image 2 de 3 Alienware 17 R4 Battery Replacement, Plastic Cover: étape 18, image 3 de 3
    • Unscrew the two M2x3 screws (1.9 mm) at the top right and top left of the laptop that hold the tron lights in place.
    Demander à FixBot
  19. Alienware 17 R4 Battery Replacement: étape 19, image 1 de 2 Alienware 17 R4 Battery Replacement: étape 19, image 2 de 2
    • Follow the wiring to unplug the tron lights.
    Demander à FixBot
  20. Alienware 17 R4 Battery Replacement: étape 20, image 1 de 3 Alienware 17 R4 Battery Replacement: étape 20, image 2 de 3 Alienware 17 R4 Battery Replacement: étape 20, image 3 de 3
    • Remove the fourteen M2.5XL8' screws (2.4 mm) located in the plastic cover using the PH1 screwdriver.
    Demander à FixBot
  21. Alienware 17 R4 Battery Replacement: étape 21, image 1 de 1
    • Use the plastic opening tool to gently lift the sides of the cover.
    Demander à FixBot
  22. Alienware 17 R4 Battery Replacement: étape 22, image 1 de 2 Alienware 17 R4 Battery Replacement: étape 22, image 2 de 2
    • Slowly lift up the plastic cover.
    Demander à FixBot
  23. Alienware 17 R4 Battery Replacement, Battery: étape 23, image 1 de 3 Alienware 17 R4 Battery Replacement, Battery: étape 23, image 2 de 3 Alienware 17 R4 Battery Replacement, Battery: étape 23, image 3 de 3
    • Unscrew the four M2.5 screws (2.4 mm) with a PH1 screwdriver bit.
    Demander à FixBot
  24. Alienware 17 R4 Battery Replacement: étape 24, image 1 de 2 Alienware 17 R4 Battery Replacement: étape 24, image 2 de 2
    • Lift the battery up to remove it.
    Demander à FixBot
32 autres ont terminé cette réparation.
Hector Mendez III
Membre depuis le 09/11/17
1 352 Réputation
8 tutoriels rédigés
Équipe
CSU Fullerton, Team S2-G4, Bruce Fall 2017 Membre de l'équipe CSU Fullerton, Team S2-G4, Bruce Fall 2017
CSUF-BRUCE-F17S2G4
4 membres
9 tutoriels rédigés
9 commentaires de tutoriel
Very good guide, just one error, step 11 comes first then step 10. You can't lift the card before remove the screw.
alex.afnet - Réponse Partager
Great guide, no issues at all!
Glenn Bell - Réponse Partager
First time I've cracked opened up a computer in decades. This step by step guide gave me the confidence I needed! Thank you so much. It took me longer, about two hours with stopping to label screws and things but everything is up and running again. I'm so happy!
Michelle - Réponse Partager
I would not recommend disconnecting the wifi card. the connectors are tiny. if you screw up, best case you need a new wifi card, worst case you are going to need to replace the antenna, and that isn’t fun.
John Wohlwend - Réponse Partager
After the battery replacement? do we need to do anything else for calibration so that the Alienware knows that it is a fresh battery and battery cycle ... as i have heard that you need to repeat 3X the process of discharging and charging for calibration. or can we just plug and play? I am getting a new battery for mine soon. Thanks =)
Yannick Docq - Réponse Partager
Nombre de vues :
Dernières 24 heures : 13
7 derniers jours : 81
30 derniers jours : 249
Total : 39,329
