Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Alienware 17 R5 Battery Replacement
Ce dont vous avez besoin
  1. Alienware 17 R5 Battery Replacement, Remove the Back Cover: étape 1, image 1 de 2 Alienware 17 R5 Battery Replacement, Remove the Back Cover: étape 1, image 2 de 2
    • Use a Phillips #0 screwdriver to remove all of the screws in the back cover.
    • If necessary, use a plastic opening tool to avoid damaging the back cover while removing it. Make sure that you are unclipping any clips that may be holding the back cover onto the laptop.
    Demander à FixBot
    Ajouter un commentaire
  2. Alienware 17 R5 Battery Replacement, Remove the Network Card: étape 2, image 1 de 3 Alienware 17 R5 Battery Replacement, Remove the Network Card: étape 2, image 2 de 3 Alienware 17 R5 Battery Replacement, Remove the Network Card: étape 2, image 3 de 3
    • Lift up the flap that covers the network card.
    • Use a spudger to undo the two wires that connect the network card to the motherboard.
    • Undo the screw holding the network card in. It will pop out at an angle.
    • Remove the network card.
    Demander à FixBot
  3. Alienware 17 R5 Battery Replacement, Remove the Second Layer of Casing that Protects the Components: étape 3, image 1 de 2 Alienware 17 R5 Battery Replacement, Remove the Second Layer of Casing that Protects the Components: étape 3, image 2 de 2
    • Remove the second layer of casing that protects the battery.
    • Make sure not to bend and or damage this layer of casing that protects all of the components while removing it. Remove any screw and or unclip any clip that may be holding it together.
    Demander à FixBot
  4. Alienware 17 R5 Battery Replacement, Remove the Cable that Connects the Battery to the Motherboard: étape 4, image 1 de 1
    • Use a spudger to unplug the battery cable from the motherboard.
    • Be sure to use ESD safe tools when removing the battery cable.
    Demander à FixBot
  5. Alienware 17 R5 Battery Replacement, Remove the Battery: étape 5, image 1 de 2 Alienware 17 R5 Battery Replacement, Remove the Battery: étape 5, image 2 de 2
    • Using a Phillips #0 screwdriver, remove the screws holding down the battery.
    Demander à FixBot
  6. Alienware 17 R5 Battery Replacement, Installing the New Battery: étape 6, image 1 de 3 Alienware 17 R5 Battery Replacement, Installing the New Battery: étape 6, image 2 de 3 Alienware 17 R5 Battery Replacement, Installing the New Battery: étape 6, image 3 de 3
    • Place the new battery in the correct position and reinstall the screws that hold the battery in place. Next , connect the cable into the battery connector.
    Demander à FixBot
  7. Alienware 17 R5 Battery Replacement, Reassemble the Device: étape 7, image 1 de 3 Alienware 17 R5 Battery Replacement, Reassemble the Device: étape 7, image 2 de 3 Alienware 17 R5 Battery Replacement, Reassemble the Device: étape 7, image 3 de 3
    • Once the battery is installed, reassemble your laptop completely and test your laptop by turning it on.
    • If your laptop does not turn on, disassemble your device and check to make sure that you did not miss anything, skip a step, that all of the connectors and cables are connected and or connected properly, and or that everything is put back together properly.
    Demander à FixBot
  8. Alienware 17 R5 Battery Replacement, Final Tests: étape 8, image 1 de 1
    • Wait for your computer to boot up and then sign in. Once you are signed in, click on the icon that looks like a battery in the bottom right corner of the screen to check the battery.
    • If the new battery can hold a charge, stays charged for a few hours, and re-enables you to use your laptop without the charger plugged in, then the new battery is working properly.
    Demander à FixBot
Ligne d'arrivée
8 autres ont terminé cette réparation.
Yubin Qin
Membre depuis le 01/09/21
256 Réputation
1 tutoriel rédigé
Équipe
York University, Team S1-G22, O'Regan Winter 2021 Membre de l'équipe York University, Team S1-G22, O'Regan Winter 2021
YORK-O'REGAN-W21S1G22
1 membre
1 tutoriel rédigé
1 commentaire de tutoriel
This guide needs a lot of work. Step 3 is especially problematic, leaving out the need to remove the panel over the connectors including how to unclip it, also disconnecting the light bars on the sides and the HDD. And how to uncip the plastic panel you are unhooking everything else to do. It needs more than just better pictures. It was enough I didn't feel right giving the credit by saying I'd made the repair (which I did).
Michael Clark - Réponse Partager
Nombre de vues :
Dernières 24 heures : 3
7 derniers jours : 45
30 derniers jours : 165
Total : 10,570
