Introduction
In this guide, we will be showing you how to remove and replace the Display Assembly.
Pièces
Aucune pièce nécessaire.
WARNING:  Before working inside your computer, read the safety information that shipped with your computer.
  • WARNING: Before working inside your computer, read the safety information that shipped with your computer.
  • CAUTION: To avoid electrostatic discharge, ground yourself by using a wrist grounding strap or by periodically touching an unpainted metal surface (such as a connector on your computer).
  • NOTE: Dell or Alienware does not guarantee compatibility or provide support for hard drives from sources other than Dell.
  • NOTE: If you are installing a hard drive from a source other than Dell or Alienware, you need to install an operating system, drivers, and utilities on the new hard drive.
Ajouter un commentaire
Loosen the two captive screws that secure the hard-drive assembly to the computer base.
  • Loosen the two captive screws that secure the hard-drive assembly to the computer base.
Using the pull-tab, pull the hard-drive assembly to disconnect the hard-drive assembly from the connector on the system board.
  • Using the pull-tab, pull the hard-drive assembly to disconnect the hard-drive assembly from the connector on the system board.
Lift the hard-drive assembly out of the computer base.
  • Lift the hard-drive assembly out of the computer base.
Kits RAM pour Mac
Accélérez votre Mac. Maximisez sa mémoire.
Kits RAM pour Mac
Augmentez la mémoire de votre Mac.
Remove the four screws that secure the hard drive to the hard-drive bracket.
  • Remove the four screws that secure the hard drive to the hard-drive bracket.
Lift the hard drive away from the hard-drive bracket.
  • Lift the hard drive away from the hard-drive bracket.
Place the NEW hard drive in the hard-drive bracket.
  • Place the NEW hard drive in the hard-drive bracket.
Replace the four screws that secure the hard-drive to the hard-drive bracket.
  • Replace the four screws that secure the hard-drive to the hard-drive bracket.
Place the hard-drive assembly in the computer base.
  • Place the hard-drive assembly in the computer base.
Use the pull-tab to push the hard drive assembly and connect it to the connector on the system board.
  • Use the pull-tab to push the hard drive assembly and connect it to the connector on the system board.
Tighten the two captive screws that secure the hard-drive assembly to the computer base.
  • Tighten the two captive screws that secure the hard-drive assembly to the computer base.
Ligne d'arrivée
2 autre(s) ont terminé cette réparation.
darrius
Membre depuis le 26/03/2018
4 577 Réputation
27 tutoriels rédigés
Équipe
Informative Technologies Inc. Membre de l'équipe Informative Technologies Inc.
Community
15 membres
845 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 4
Total : 19
