Introduction
In this guide, we will be showing you how to remove and replace the Battery Pack.
Pièces
Aucune pièce nécessaire.
WARNING: Before working inside your computer, read the safety information that shipped with your computer.
  • WARNING: Before working inside your computer, read the safety information that shipped with your computer.
  • CAUTION: To avoid electrostatic discharge, ground yourself by using a wrist grounding strap or by periodically touching an unpainted metal surface (such as a connector on your computer).
  • Turn the computer over.
Ajouter un commentaire
Loosen the eight captive screws that secure the base cover to the computer base.
  • Loosen the eight captive screws that secure the base cover to the computer base.
Lift the base cover off the computer base.
  • Lift the base cover off the computer base.
Align the tabs on the NEW base cover with the slots on the computer base and place the base cover in position.
  • Align the tabs on the NEW base cover with the slots on the computer base and place the base cover in position.
Mac RAM Kits
Speed up your Mac. Max out its memory.
Mac RAM Kits
Get more memory out of your Mac.
Tighten the eight screws that secure the base cover to the computer base.
  • Tighten the eight screws that secure the base cover to the computer base.
  • Remove the two screws that secure the battery pack to the computer base.
Disconnect the battery pack cable from the connector on the system board.
  • Disconnect the battery pack cable from the connector on the system board.
Using the pull-tab, lift the battery pack off the computer base.
  • Using the pull-tab, lift the battery pack off the computer base.
Place the NEW battery pack in the battery bay and replace the two screws that secure the battery pack to the computer base.
  • Place the NEW battery pack in the battery bay and replace the two screws that secure the battery pack to the computer base.
Route the battery pack cable in the routing guide
  • Route the battery pack cable in the routing guide
Connect the battery pack cable to the connector on the system board.
  • Connect the battery pack cable to the connector on the system board.
Ligne d'arrivée
2 autre(s) ont terminé cette réparation.
darrius
Membre depuis le 26/03/2018
4 577 Réputation
27 tutoriels rédigés
Équipe
Informative Technologies Inc. Membre de l'équipe Informative Technologies Inc.
Community
15 membres
833 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 2
Total : 15
