Introduction
How to remove and replace Coin-Cell Battery
Pièces
Aucune pièce nécessaire.
WARNING: Before working inside your computer, read the safety information that shipped with your computer.
  • WARNING: Before working inside your computer, read the safety information that shipped with your computer.
  • CAUTION: To avoid electrostatic discharge, ground yourself by using a wrist grounding strap or by periodically touching an unpainted metal surface (such as a connector on your computer).
  • Turn the computer over.
Ajouter un commentaire
Loosen the eight captive screws that secure the base cover to the computer base.
  • Loosen the eight captive screws that secure the base cover to the computer base.
Lift the base cover off the computer base.
  • Lift the base cover off the computer base.
Align the tabs on the NEW base cover with the slots on the computer base and place the base cover in position.
  • Align the tabs on the NEW base cover with the slots on the computer base and place the base cover in position.
Tighten the eight screws that secure the base cover to the computer base.
  • Tighten the eight screws that secure the base cover to the computer base.
  • Disconnect the coin-cell battery cable from the connector on the system board.
The coin-cell battery is glued to the system board. Using a plastic scribe, pry the coin-cell battery from the system board.
  • The coin-cell battery is glued to the system board. Using a plastic scribe, pry the coin-cell battery from the system board.
Use the adhesive on NEW the coin-cell battery and adhere it to the system board.
  • Use the adhesive on NEW the coin-cell battery and adhere it to the system board.
Connect the coin-cell battery cable to the connector on the system board.
  • Connect the coin-cell battery cable to the connector on the system board.
3 autre(s) ont terminé cette réparation.
darrius
Membre depuis le 26/03/2018
4 577 Réputation
27 tutoriels rédigés
Équipe
Informative Technologies Inc. Membre de l'équipe Informative Technologies Inc.
Community
15 membres
828 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 2
Total : 19
