Introduction
This guide shows how to replace the WiFi card on an Alienware M18x.
Pièces
Aucune pièce nécessaire.
Turn your computer over. Slide bar over and lift battery out.
  • Turn your computer over.
  • Slide bar over and lift battery out.
Ajouter un commentaire
Unscrew the four screws with a J000 screwdriver.
  • Unscrew the four screws with a J000 screwdriver.
Kits RAM pour Mac
Accélérez votre Mac. Maximisez sa mémoire.
Kits RAM pour Mac
Augmentez la mémoire de votre Mac.
Use the plastic pryer tool to lift the bottom cover off. Use the plastic pryer tool to lift the bottom cover off.
  • Use the plastic pryer tool to lift the bottom cover off.
Unscrew the two screws with a J00 screwdriver.
  • Unscrew the two screws with a J00 screwdriver.
Pull the WiFi card out.
  • Pull the WiFi card out.
  • Disconnect the black and white antenna cables.
Rachel Greenberg
Membre depuis le 21/02/2018
325 Réputation
3 tutoriels rédigés
Équipe
Cal Poly, Team S21-G1, Banghart Winter 2018 Membre de l'équipe Cal Poly, Team S21-G1, Banghart Winter 2018
CPSU-BANGHART-W18S21G1
4 membres
5 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 0
Total : 16
