Aller au contenu principal
Alienware P18G M14X R1 RAM Replacement
Ce dont vous avez besoin
  1. Alienware P18G M14X R1 RAM Replacement, Back Cover: étape 1, image 1 de 1
    • Loosen the top left and top right 6.5mm PH1 screws that hold down the back cover.
    • The screws will not be able to be removed from the back cover. They can only be loosened or tightened.
  2. Alienware P18G M14X R1 RAM Replacement: étape 2, image 1 de 1
    • Slide back cover forward using your thumbs.
  3. Alienware P18G M14X R1 RAM Replacement: étape 3, image 1 de 1
    • Lift up the cover and set aside exposing the internals of the computer.
  4. Alienware P18G M14X R1 RAM Replacement, RAM: étape 4, image 1 de 1
    • Unscrew the two 6.35 mm using the PH1 screw driver.
  5. Alienware P18G M14X R1 RAM Replacement: étape 5, image 1 de 2 Alienware P18G M14X R1 RAM Replacement: étape 5, image 2 de 2
    • Lift the plate and remove it to uncover the RAM sticks.
  6. Alienware P18G M14X R1 RAM Replacement: étape 6, image 1 de 1
    • Push outward on the prongs that secure the RAM stick in the slots.
    • After releasing the prongs the rams stick will rise up.
  7. Alienware P18G M14X R1 RAM Replacement: étape 7, image 1 de 1
    • Be very gentle in this step, making sure to not damage anything.
    • Pull the RAM stick out of its housing.
  8. Alienware P18G M14X R1 RAM Replacement: étape 8, image 1 de 1
  9. Alienware P18G M14X R1 RAM Replacement: étape 9, image 1 de 1
    • Pull the second ram stick out of its housing.
Andonaq Grozdani
Membre depuis le 03/01/18
892 Réputation
5 tutoriels rédigés
Équipe
UMass Dartmouth, Team S2-G2, Simcock Spring 2018 Membre de l'équipe UMass Dartmouth, Team S2-G2, Simcock Spring 2018
UMASSD-SIMCOCK-S18S2G2
3 membres
5 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 8
Total : 988
