Introduction
The front panel may need to be replaced if it is cracked or damaged.
Pièces
Aucune pièce nécessaire.
Power off your AlphaSmart Pro device and remove the batteries before beginning disassembly. Remove all eight 1 cm Phillips head screws from the back panel of the AlphaSmart Pro with the Phillips #00 Screwdriver. Carefully separate the front panel from the back panel.
  • Power off your AlphaSmart Pro device and remove the batteries before beginning disassembly.
  • Remove all eight 1 cm Phillips head screws from the back panel of the AlphaSmart Pro with the Phillips #00 Screwdriver.
  • Carefully separate the front panel from the back panel.
  • Notice that the front and back panels are still connected by a ribbon cable.
Ajouter un commentaire
To remove the ribbon cable, use the spudger to lift each side of the connector from the socket. Gently pull up on the connector to completely remove the connector from the socket.
  • To remove the ribbon cable, use the spudger to lift each side of the connector from the socket.
  • Gently pull up on the connector to completely remove the connector from the socket.
  • You are now able to separate the front panel from the back panel.
Looking at the front panel, use the Phillips #00 screwdriver to remove the four Phillips head 0.8 cm screws from each corner of the display motherboard. Lift the display screen and motherboard from the plastic front panel to separate the two pieces. Lift the display screen and motherboard from the plastic front panel to separate the two pieces.
  • Looking at the front panel, use the Phillips #00 screwdriver to remove the four Phillips head 0.8 cm screws from each corner of the display motherboard.
  • Lift the display screen and motherboard from the plastic front panel to separate the two pieces.
Nathan Smith
Membre depuis le 13/10/2014
4 Réputation
2 tutoriels rédigés
Équipe
Clemson, Team 1-1, Benson Fall 2014 Membre de l'équipe Clemson, Team 1-1, Benson Fall 2014
CLEM-BENSON-F14S1G1
4 membres
8 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 0
Total : 152
