Introduction
If your Altec Lansing Mini Lifejacket 2's speaker is damaged or faulty, use the following step-by-step guide to replace it. This guide applies to both the speakers.
Remove the three 9.3 mm Phillips #1 screws on the speaker cover. Remove the three 9.3 mm Phillips #1 screws on the speaker cover.
  • Remove the three 9.3 mm Phillips #1 screws on the speaker cover.
Ajouter un commentaire
Kits RAM pour Mac
Accélérez votre Mac. Maximisez sa mémoire.
Kits RAM pour Mac
Augmentez la mémoire de votre Mac.
To remove the speaker, gently pull out the its wire harness. To remove the speaker, gently pull out the its wire harness. To remove the speaker, gently pull out the its wire harness.
  • To remove the speaker, gently pull out the its wire harness.
Remove the rubber ring from the rim of the speaker. This ring helps keep water from entering the device. Be careful to position it correctly during reassembly.
  • Remove the rubber ring from the rim of the speaker.
  • This ring helps keep water from entering the device. Be careful to position it correctly during reassembly.
Stephen Albrecht
Membre depuis le 14/02/2018
675 Réputation
4 tutoriels rédigés
Équipe
USF Tampa, Team S3-G2, Nance Spring 2018 Membre de l'équipe USF Tampa, Team S3-G2, Nance Spring 2018
USFT-NANCE-S18S3G2
4 membres
4 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 11
30 derniers jours : 32
Total : 84
