Introduction
Use this guide to replace the 4-in-1 WiFi/Bluetooth/FM/GPS board on the Amazon Echo Dot 2nd generation. The 4-in-1 is located on the motherboard, so the whole board must be replaced, rather than replacing each individual component.
Power off and unplug the echo Using the plastic opening tool, peel off the rubber layer on the bottom of the echo Using the plastic opening tool, peel off the rubber layer on the bottom of the echo
  • Power off and unplug the echo
  • Using the plastic opening tool, peel off the rubber layer on the bottom of the echo
Ajouter un commentaire
Use a T8 screwdriver bit to unscrew the four 1.6mm torx screws Remove the black cylindrical base Remove the black cylindrical base
  • Use a T8 screwdriver bit to unscrew the four 1.6mm torx screws
  • Remove the black cylindrical base
Kits RAM pour Mac
Accélérez votre Mac. Maximisez sa mémoire.
Kits RAM pour Mac
Augmentez la mémoire de votre Mac.
Use the metal spudger to lift the ZIF connector Remove the ribbon cable from the slot Remove the ribbon cable from the slot
  • Use the metal spudger to lift the ZIF connector
  • Remove the ribbon cable from the slot
Remove the motherboard
  • Remove the motherboard
Alexis White
Membre depuis le 09/10/2017
213 Réputation
4 tutoriels rédigés
Équipe
USF Tampa, Team S1-G3, Leahy Fall 2017 Membre de l'équipe USF Tampa, Team S1-G3, Leahy Fall 2017
USFT-LEAHY-F17S1G3
3 membres
10 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 5
7 derniers jours : 24
30 derniers jours : 154
Total : 1,152
