Aller au contenu principal
Amazon Echo Dot 2nd Generation LED/Speaker Board and Microphone Replacement
Ce dont vous avez besoin
  1. Amazon Echo Dot 2nd Generation LED/Speaker Board and Microphone Replacement, LED/Speaker Board and Microphone: étape 1, image 1 de 3 Amazon Echo Dot 2nd Generation LED/Speaker Board and Microphone Replacement, LED/Speaker Board and Microphone: étape 1, image 2 de 3 Amazon Echo Dot 2nd Generation LED/Speaker Board and Microphone Replacement, LED/Speaker Board and Microphone: étape 1, image 3 de 3
    • Power off and unplug the echo
    • Using the plastic opening tool, peel off the rubber layer on the bottom of the echo.
  2. Amazon Echo Dot 2nd Generation LED/Speaker Board and Microphone Replacement: étape 2, image 1 de 3 Amazon Echo Dot 2nd Generation LED/Speaker Board and Microphone Replacement: étape 2, image 2 de 3 Amazon Echo Dot 2nd Generation LED/Speaker Board and Microphone Replacement: étape 2, image 3 de 3
    • Use the T8 screwdriver bit to unscrew the four 1.6mm torx screws
    • Remove the black cylindrical base
  3. Amazon Echo Dot 2nd Generation LED/Speaker Board and Microphone Replacement: étape 3, image 1 de 3 Amazon Echo Dot 2nd Generation LED/Speaker Board and Microphone Replacement: étape 3, image 2 de 3 Amazon Echo Dot 2nd Generation LED/Speaker Board and Microphone Replacement: étape 3, image 3 de 3
    • Use the metal spudger to lift the ZIF connector
    • Remove the ribbon cable from the slot
  4. Amazon Echo Dot 2nd Generation LED/Speaker Board and Microphone Replacement: étape 4, image 1 de 1
    • Remove the motherboard
  5. Amazon Echo Dot 2nd Generation LED/Speaker Board and Microphone Replacement: étape 5, image 1 de 3 Amazon Echo Dot 2nd Generation LED/Speaker Board and Microphone Replacement: étape 5, image 2 de 3 Amazon Echo Dot 2nd Generation LED/Speaker Board and Microphone Replacement: étape 5, image 3 de 3
    • Remove the silver divider
    • Remove black rubber divider
    • Remove the plastic white frame
  6. Amazon Echo Dot 2nd Generation LED/Speaker Board and Microphone Replacement: étape 6, image 1 de 3 Amazon Echo Dot 2nd Generation LED/Speaker Board and Microphone Replacement: étape 6, image 2 de 3 Amazon Echo Dot 2nd Generation LED/Speaker Board and Microphone Replacement: étape 6, image 3 de 3
    • Remove the ribbon cable from the slot on the LED/speaker board
  7. Amazon Echo Dot 2nd Generation LED/Speaker Board and Microphone Replacement: étape 7, image 1 de 1
    • Remove the LED/speaker board
4 autres ont terminé cette réparation.
Cassidy O'Connor
Membre depuis le 10/09/17
450 Réputation
2 tutoriels rédigés
Équipe
USF Tampa, Team S1-G3, Leahy Fall 2017 Membre de l'équipe USF Tampa, Team S1-G3, Leahy Fall 2017
USFT-LEAHY-F17S1G3
3 membres
12 tutoriels rédigés
Un commentaire
I can’t seem to find the board anywhere. Where would you buy one?
George hanes - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 8
30 derniers jours : 30
Total : 4,866
