Aller au contenu principal
Amazon Fire HD 10 Screen Replacement
Ce dont vous avez besoin
  1. Amazon Fire HD 10 Screen Replacement, Screen: étape 1, image 1 de 3 Amazon Fire HD 10 Screen Replacement, Screen: étape 1, image 2 de 3 Amazon Fire HD 10 Screen Replacement, Screen: étape 1, image 3 de 3
    • Avoid prying near bottom right hand side due to LCD Connector
    • Use a plastic opening tool to pry the screen up in the right hand corner.
  2. Amazon Fire HD 10 Screen Replacement: étape 2, image 1 de 1
    • Do not completely remove the screen yet as there is a ZIF connector connected.
    • Lift the screen and digitizer from the case.
    • You may need to use some force due to the glue.
  3. Amazon Fire HD 10 Screen Replacement: étape 3, image 1 de 2 Amazon Fire HD 10 Screen Replacement: étape 3, image 2 de 2
    • Be mindful of the ZIF connector.
    • Disconnect the ribbon connector from the digitizer side using your hands or the plastic opening tool.
  4. Amazon Fire HD 10 Screen Replacement: étape 4, image 1 de 1
    • Remove the screen and digitizer from the case completely.
26 autres ont terminé cette réparation.
Jaie Hillery
Membre depuis le 10/07/14
1 718 Réputation
10 tutoriels rédigés
Équipe
USF Tampa, Team 16-6, Blackwell Winter 2016 Membre de l'équipe USF Tampa, Team 16-6, Blackwell Winter 2016
USFT-BLACKWELL-W16S16G6
3 membres
22 tutoriels rédigés
16 commentaires
Where can you get a replacement digitizer screen? My grandson dropped his a couple days ago & I don't want to spend another $200 for a new one.
misterh - Réponse
I am seeing replacement screen/digitizers for these now on ebay. With a little searching around I found one direct ship from Hong Kong for $70US. Good Luck!
Greg Charland -
I can't seem the find a replacement screen for this specification anywhere
Stephanie Eyime - Réponse
I need the the cable that goes to the sceen. As i changed out my battery, when i tried to carefully remove the zif connector, it broke off. Woe is me.
boumpanimusic - Réponse
What is needed to attach the screen back to the case?
Jimmy Lee - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 10
7 derniers jours : 66
30 derniers jours : 215
Total : 35,003
